[SOLVED] System wont Post
frase
Melbourne, Australia
Have a new build
Gigabyte A520M-DS3H
AMD Ryzen 5 1600AF
G.Skill 8GB DDR4 2400
It powers up fan spin - no post?
Tried everything -
Reset CMOS
Reset BIOS
Used different GFX Cards
Swapped RAM into each slot
Different PSU
RAM timing is ok, would that be an issue?
The BIOS should not need Flash as not latest Ryzen.
Ran out of Ideas..
POST or actualy boot ?
Unplug and disable everything including the RAM, count the bleep code and look it up, add things one by one and re check the bleep codes each time.
I have had to deal with boards in the past that would not boot untill the chipset driver was loaded, and then everything had to be added one at a time :(
Purchased another board all good. Need to pay more attention to compatability. Have used other board in another system build already, so no loss just wisdom gained.
Normally only intel, though this a budget build. Cheers all!
