commentator8
I have a computer (details below) which shows its connected to the net in network and sharing center, outlook and skype connect fine but browsers and windows update/mse/malawarebytes dont. I am almost positive that it is not a virus, but have run a malawarebytes scan in case. The issue began 3 years back (they didn't require internet till now) upon installing a web filtering program (not a known one) and having it crash midway through the install. I have run "complete internet repair", manual winsock fix, hijack this, autoruns (and checked the drivers - k9 has one there), win.ini from an off reference from a site, uninstalled the latest windows update (sp1), put a manual dns server entry, reset tcp stack and other varieties thereoff "netsh int ip reset", checked the host file, proxy settings, reset windows services to default, confirmed the tcp ip settings are valid (and default), the firewall is off and likely other things. It is currently connected to my own connection.
I have tried firefox, https in ie, reset ie settings, windows safe mode, sfc /scannow, a different internet connection, wired/wireless, tcp optimiser. Ping works and skype etc, but not browsers. System restore is out of the question as it was three years ago. I have also tried a new user account.
That said, when i try and open a web site it sits at waiting for/ website found waiting for "" till it times out (IE cannot display the webpage). This also occurs if i use an ip (google's etc). Windows update/mse and malawarebytes, but skype and outlook work fine. Seems to imply a port issue. Norton/macaffee/zonealarm/etc are not installed, and add or remove programs has no security programs that i can see.
Any ideas of what it could be?
Toshiba
Vista SP2/1 (uninstalled) Home Premium 32 bit
Toshiba
