Doc+Com
- Franklin, IN
I got a late 2009 21" iMac in a few days ago, the customer was complaining of being unable to install the 10.6.8 combo update (10.6.3 was installed) and everything working slow.
The update is pending and appears to download and attempts to reinstall but fails saying that the system needs to be rebooted to repair the drive. This leads to a 'boot loop' scenario which led to me using a 10.6.3 M/Lion disk to run Disk utility and repair the drive.
Re-attempts at installing the update leads to the same result.
I pull the hard drive and take an image, I read smart (no issues) and run a surface test on the drive (no issues).
After consulting with my client, I fully erase the drive, partition (1 part, GUID) and format 'extended-Journaled' to do a clean install using the 10.6.3 disk. The install runs until is shows 29% and then stops saying that the installation failed "The installer could not copy the necessary support files".
I formatted/partitioned a new hard drive and tried the installation again with the same result. I know this is sounding like a bad OSX DVD or drive cable but I bought the DVD back in 2004 from Apple and have probably used it 3 times since then...so it could still be bad...but!
I've also read online about others having similar issues and tried another disk (even a USB install) without success...but also without a solution to the issue.
I really would like to know if anyone has had an experience like this or know of anything I may have missed before I go throwing parts at this at my client's expense...I don't get enough Macs to obtain much a real knowledge base.
