Hi all,
Got a HP dv6-6b06sa in needed OS reinstalling, license worn away so ordered the recovery media.
Tried numerous times with;
Battery out,
Battery in,
Swapped ram,
Swapped hdd,
cleared bios/cmos,
etc.
I'm at a loose end with an error message:
"The recovery attempt has failed."
All help much appreciated.
Dom
Logs below:
[13:11:57.59] Entering Checking OS Edition...
[13:11:57.60] Check RStone.ini file to determine the requried edition.
[13:11:57.63] Exiting Checking OS Edition...
[13:11:57.65] Check if Upgrading Win 7 is required.
[13:11:57.66] Current Edition is [HomeBasic]...
[13:11:57.66] Required [Starter]. Don't need to upgrade...
[13:11:57.68] Required [Starter] ...
[13:12:02.69] Required [Starter] Edition. But, OS is not [Starter]...
[13:12:02.69] Upgrading OS edition might have some problem...
Deployment Image Servicing and Management tool
Version: 6.1.7600.16385
Image Version: 6.1.7601.17514
Current edition is:
Current Edition : HomeBasic
The operation completed successfully.
Component: TDC Preinstall Diagnostic Tools for Windows 7 - TDC
Error found: No OS Flag set on unit, please use EEPROM to set ~OS SKU~ value = 2
[13:12:58.04] ------------------------------------------------------------------------------------------
***CTO Error condition has been dtected in [Factory Update] phase !! ***
[13:12:58.04] Suggest to create PIN-log and send to TWN PDC NB-PreinPM for further analysis ...
[13:11:03.02] Start BBOffline.cmd...
UPDrv=[C:]
[13:11:03.05] Set UIA Error Code to 951
[13:11:03.72] WinPE is 32bit.
[13:11:03.72] Starts [FixUps].
[13:11:03.78] ---------------------------------------------------------------------
[13:11:03.78] FixUps.cmd...
[13:11:03.78] create overall progress info...
[13:11:05.53] FixUps.cmd completed...
[13:11:05.53] ---------------------------------------------------------------------
[13:11:05.53] Starts [Tweaks for SSRD].
[13:11:05.54] ---------------------------------------------------------------------
[13:11:05.54] SSRD Tweaks to change user default locale...
[13:11:05.54] Copy C:\System.sav\Util\TDC\MCPP\FBIRES\FBIUSRES.DLL.
[13:11:05.67] Run "Dism.exe /image:C:\ /Set-SKUIntlDefaults:en-US -image:C:".
[13:11:13.86] ---------------------------------------------------------------------
[13:11:13.86] Launch PININST.exe for Offline ...
[13:11:26.56] Starts [Sleep 10 sec].
[13:11:36.62] Starts [Create RStoneFUpdate.INI].
[13:11:48.15] Starts [create 1GB Pagefile for offline].
Volume in drive C has no label.
Volume Serial Number is 8271-5406
Directory of C:\system.sav\bbv
01/17/2012 01:11 PM 1,073,741,824 pagefile.sys
1 File(s) 1,073,741,824 bytes
0 Dir(s) 45,456,949,248 bytes free
[13:11:48.24] Brand detection.
[13:11:48.51] ---------------------------------------------------------------------
[13:12:35.96] Start SysID Check...
[13:12:36.30] Start Option Code Checks...
SKU_DEF_COUNTRY=[242]
SKU_DEF_SYS_LOC=[en-GB]
Reset country in administrator...
Reset country in Default user...
Reset System localed
Reporting offline international settings.
Default system UI language : en-US
System locale : en-GB
Default time zone : Pacific Standard Time
User locale for default user : en-US
Active keyboard(s) : 0409:00000409
Keyboard layered driver : PC/AT Enhanced Keyboard (101/102-Key)
Installed language(s): en-US
Type : Fully localized language.
Updated System Locale info..
[13:12:52.42] Start PIN Tweaks...
[13:12:52.45] ---------------------------------------------------------------------
[13:12:52.45] PIN Tweaks to hide All for BurnBoot BBV and BBV2 on restored image...
[13:12:52.47] ----------------------------------------
[13:12:52.47] Tweaks for OOBE's Unattend.xml
[13:12:52.47] to pick up the proper file...
[13:12:52.47] rename unattend.org to unattend.or_
[13:12:52.50] ----------------------------------------
[13:12:52.50] without Light Sensor..
[13:12:52.51] ----------------------------------------
[13:12:52.53] This is Restored image by SSRD [SSRD.flg]...
[13:12:52.53] ---------------------------------------------------------------------
[13:12:52.56] Start MIR Tweaks...
[13:12:52.59] ---------------------------------------------------------------------
[13:12:52.59] [MIR Tweaks] ...
[13:12:52.61] ---------------------------------------------------------------------
[13:12:52.64] Start Factory Update(s)...
[13:12:55.17] Start QFE Offline installation...
[13:12:57.85] PININST_OFF: PASSED...
[13:12:57.90] Type C:\System.sav\Logs\BBFindEr.log...
[13:12:57.91] Type C:\System.sav\Logs\BBFindE0.log...
---------- C:\SYSTEM.SAV\LOGS\PININST_OFF.LOG
Result=PASSED
[13:12:57.94] Type C:\System.sav\Logs\BBFindEr.log...
[13:12:57.94] Type C:\System.sav\Logs\BBFindE0.log...
---------- C:\SYSTEM.SAV\LOGS\BBFIND4QFE.LOG
[13:12:57.96] Check FUList.log if there is duplicate Desc...
No duplication.
[13:12:58.02] No Duplicated Desc is found... PASSED.
[13:12:58.02] There was no Factory Update...
Battery out,
Battery in,
Swapped ram,
Swapped hdd,
cleared bios/cmos,
etc.
Dom
Logs below:
Current edition is:
UPDrv=[C:]
Result=PASSED
No duplication.
