Errors with Dell Reinstall Disc on Dell PC?
Edge Tech NY
Long Island, New York
I have a few install discs for dells that ive collected and everyone gave a "Install Device CDROM/DiskDrive" error during the "Installing Devices" phase.. I press ok and the install finishes, boots to a BSOD.. Any reason why? Thanks
Either the Dell cd you are using has drivers for totally different hardware or the machine has had a hardware upgrade. If this is not the case then you have some bad hardware, most likely memory or hard drive. I would run a hardware test.
Either way it's got to bad drivers or bad hardware.
Good luck!:)
I agree with frostbyte. the cd's run an app to ensure that the PC is a dell if it is then it install if is not then it wont install. If anything was added to the machine it needs to be removed and the original component be added. I once had a PC that had additional memory and I could not run the cd until I removed extra memory.
