carmen617
- Boston, MA
OK, apologies in advance for the length of this post, but . . .
So, I do residential break fix and this system isn't that old - originally came with Windows 8, crappy consumer level 17" Dell laptop. Client calls to tell me she can't boot the system, it's been slow and balky and now it won't load at all, it's just making an awful beeping noise. I diagnose over the phone as a potential bad hard drive, tell her I can replace the drive with an SSD and maybe get her data, maybe not. She says data not that important, she doesn't use it much but wants it for ZOOM meetings, just fix it as I see best, and drops it off for a drive replacement.
When I get the system the battery is drained, and when I plug in a charger, no response. However, removing the battery and power supply, holding the power button down for a minute, and giving it juice again does its magic and the system boots directly to her user account. It's definitely slow as molasses, but I'm in Windows with all her settings and software so I decide to attempt to clone the drive using my usual - a new Samsung 860 EVO and the Samsung Data Migration software for the clone.
The clone fails twice, saying there are errors on the drive (yay, good phone diagnosis!). It recommends I run chkdsk, so I figure, no harm no foul, and set it to run at startup. I restart the system, and this time I get the problem the client called about. However, this sound at boot is not like anything I have ever heard before. It sounds mechanical, for sure, but it's not a typical Dell beep code, or that awful click of a failed drive. It's more a loud BOOP BOOP BOOP with an uptick at the end. Kind of BOOup BOOup BOOup - every 5 seconds or so.
Weird noise, but OK fine, I'll just replace the hard drive, do a clean install, FABS it over as I originally intended. So i remove the old drive, install my Samsung SSD, plug in a Window 10 flash drive, turn on the system - and I get the same damned BOOup BOOup BOOup noise with my new drive. Crap.
I do the magical power drain dance again and the system boots fine. I run the built in Dell diagnostics, and the system passes every test. What the hell is going on here? Can I do the clean install/FABS routine, or is the system a ticking time bomb that's going to not boot a few days after I return it to the owner and cash her check? Seriously I'm happy to tell her all that has gone on and ask her what she wants me to do, but I have no idea what's causing that BOOup noise and want to give her some idea of her next best step forward.
