XP faster setting
daynish
DISABLE INDEXING SERVICES
Indexing Services is a small little program that uses large amounts of RAM and can often make a computer endlessly loud and noisy. This system process indexes and updates lists of all the files that are on your computer. It does this so that when you do a search for something on your computer, it will search faster by scanning the index lists. If you don't search your computer often, or even if you do search often, this system service is completely unnecessary. To disable do the following:
1. Go to Start
2. ###### Settings
3. ###### Control Panel
4. Double-###### Add/Remove Programs
5. ###### the Add/Remove Window Components
6. Uncheck the Indexing services
7. ###### Next
OPTIMISE DISPLAY SETTINGS
Windows XP can look sexy but displaying all the visual items can waste system resources. To optimise:
1.Go to Start
2. ###### Settings
4. ###### System
5. ###### Advanced tab
6. In the Performance tab ###### Settings
7. Leave only the following ticked:
- Show shadows under menus
- Show shadows under mouse pointer
- Show translucent selection rectangle
- Use drop shadows for icons labels on the desktop
- Use visual styles on windows and buttons
DISABLE PERFORMANCE COUNTERS
Windows XP has a performance monitor utility which monitors several areas of your PC's performance. These utilities take up system resources so disabling is a good idea.
To disable:
1. download and install the Extensible Performance Counter List
2.Then select each counter in turn in the 'Extensible performance counters' window and clear the 'performance counters enabled' checkbox at the bottom.button below.
SPEEDUP FOLDER BROWSING
You may have noticed that everytime you open my computer to browse folders that there is a slight delay. This is because Windows XP automatically searches for network files and printers everytime you open Windows Explorer. To fix this and to increase browsing significantly:
1. Open My Computer
2. ###### on Tools menu
3. ###### on Folder Options
4. ###### on the View tab.
5. Uncheck the Automatically search for network folders and printers check box
6. ###### Apply
7. ###### Ok
8. Reboot your computer
IMPROVE MEMORY USAGE
Cacheman Improves the performance of your computer by optimizing the disk cache, memory and a number of other settings.
Once Installed:
1.Go to Show Wizard and select All
2.Run all the wizards by selecting Next or Finished until you are back to the main menu. Use the defaults unless you know exactly what you are doing.
3.Exit and Save Cacheman
4.Restart Windows
OPTIMISE YOUR PAGEFILE
If you give your pagefile a fixed size it saves the operating system from needing to resize the page file.
1. Right ###### on My Computer and select Properties
2. Select the Advanced tab
3. Under Performance choose the Settings button
4. Select the Advanced tab again and under Virtual Memory select Change
5. Highlight the drive containing your page file and make the initial Size of the file the same as the Maximum Size of the file.
Windows XP sizes the page file to about 1.5X the amount of actual physical memory by default. While this is good for systems with smaller amounts of memory (under 512MB) it is unlikely that a typical XP desktop system will ever need 1.5 X 512MB or more of virtual memory. If you have less than 512MB of memory, leave the page file at its default size. If you have 512MB or more, change the ratio to 1:1 page file size to physical memory size.
RUN BOOTVIS - IMPROVE BOOT TIMES
BootVis will significantly improve boot times
1. Download and Run
2. Select Trace
3. Select Next Boot and Driver Trace
4. A Trace Repetitions screen will appear, select Ok and Reboot
5. Upon reboot, BootVis will automatically start, analyze and log your system's boot process. When it's done, in the menu go to Trace and select Optimize System
6. Reboot.
7. When your machine has rebooted wait until you see the Optimizing System box appear. Be patient and wait for the process to complete
REMOVE THE DESKTOP PICTURE
Your desktop background consumes a fair amount of memory and can slow the loading time of your system. Removing it will improve performance.
1. Right ###### on Desktop and select Properties
2. Select the Desktop tab
3. In the Background window select None
4. ###### Ok
REMOVE FONTS FOR SPEED
Fonts, especially TrueType fonts, use quite a bit of system resources. For optimal performance, trim your fonts down to just those that you need to use on a daily basis and fonts that applications may require.
1. Open Control Panel
2. Open Fonts folder
3. Move fonts you don't need to a temporary directory (e.g. C:\FONTBKUP?) just in case you need or want to bring a few of them back. The more fonts you uninstall, the more system resources you will gain.
DISABLE UNNECESSARY SERVICES
Because Windows XP has to be all things to all people it has many services running that take up system resources that you will never need. Below is a list of services that can be disabled on most machines:
Alerter
Clipbook
Computer Browser
Distributed Link Tracking Client
Fast User Switching
Help and Support - (If you use Windows Help and Support leave this enabled)
Human Interface Access Devices
Indexing Service
IPSEC Services
Messenger
Netmeeting Remote Desktop Sharing (disabled for extra security)
Portable Media Serial Number
Remote Desktop Help Session Manager (disabled for extra security)
Remote Procedure Call Locator
Remote Registry (disabled for extra security)
Remote Registry Service
Secondary Logon
Routing & Remote Access (disabled for extra security)
Server
SSDP Discovery Service - (Unplug n' Pray will disable this)
Telnet
TCP/IP NetBIOS Helper
Upload Manager
Universal Plug and Play Device Host
Windows Time
Wireless Zero Configuration (Do not disable if you use a wireless network)
Workstation
To disable these services:
Go to Start and then Run and type "services.msc"
Doubleclick on the service you want to change
Change the startup type to 'Disable"
TURN OFF SYSTEM RESTORE
System Restore can be a useful if your computer is having problems, however storing all the restore points can literally take up Gigabytes of space on your hard drive. To turn off System Restore:
Open Control Panel
###### on Performance and Maintenance
###### on System
###### on the System Restore tab
Tick 'Turn off System Restore on All Drives'
###### 'Ok'
DISABLE THE WINDOWS BOOT LOGO
Many sites recommend disabling the animated Windows boot logo to help speed up the time it takes to boot. Although it may decrease the time by a couple seconds, the anxiety caused by facing a blank screen and wondering if Windows has stalled or froze during bootup outweighs the second or two you may save. Although if you wish to disable the Windows boot logo, follow these steps:
1) Click on Start, Run and type MSCONFIG and press Enter
2) Click on the BOOT.INI tab
3) Click the NOGUIBOOT checkbox and click OK
4) Reboot the computer
DEFRAGMENT YOUR PAGEFILE
Keeping your pagefile defragmented can provide a major performance boost. One of the best ways of doing this is to creat a separate partition on your hard drive just for your page file, so that it doesn't get impacted by normal disk usage. Another way of keeping your pagefile defragmented is to run PageDefrag. This cool little app can be used to defrag your pagefile, and can also be set to defrag the pagefile everytime your PC starts. To install:
Download and Run PageDefrag
Tick "Defrag at next Reboot",
###### "Ok"
Reboot
SPEEDUP FOLDER ACCESS - DISABLE LAST ACCESS UPDATE
If you have a lot of folders and subdirectories on your computer, when you access a directory XP wastes a lot of time updating the time stamp showing the last access time for that directory and for ALL sub directories. To stop XP doing this you need to edit the registry. If you are uncomfortable doing this then please do not attempt.
Go to Start and then Run and type "regedit"
###### through the file system until you get to "HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem"
Right-###### in a blank area of the window on the right and select 'DWORD Value'
Create a new DWORD Value called 'NtfsDisableLastAccessUpdate'
Then Right ###### on the new value and select 'Modify'
Change the Value Data to '1'
###### 'OK'
DISABLE SYSTEM SOUNDS
Surprisingly, the beeps that your computer makes for various system sounds can slow it down, particularly at startup and shut-down. To fix this turn off the system sounds:
Open Control Panel
###### Sounds and Audio Devices
Check Place volume icon in taskbar
###### Sounds Tab
Choose "No Sounds" for the Sound Scheme
###### "No"
###### "Apply"
###### "OK"
IMPROVE BOOT TIMES
A great new feature in Microsoft Windows XP is the ability to do a boot defragment. This places all boot files next to each other on the disk to allow for faster booting. By default this option in enables but on some builds it is not so below is how to turn it on.
Go to Start Menu and ###### Run
Type in "Regedit" then ###### ok
Find "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOpt imizeFunction"
Select "Enable" from the list on the right
Right on it and select "Modify"
Change the value to "Y to enable"
Reboot
IMPROVE SWAPFILE PERFORMANCE
If you have more than 256MB of RAM this tweak will considerably improve your performance. It basically makes sure that your PC uses every last drop of memory (faster than swap file) before it starts using the swap file.
Go to Start then Run
Type "msconfig.exe" then ok
###### on the System.ini tab
Expand the 386enh tab by *** on the plus sign
###### on new then in the blank box type"ConservativeSwapfileUsage=1"
###### OK
Restart PC
MAKE YOUR MENUS LOAD FASTER
This is one of my favourite tweaks as it makes a huge difference to how fast your machine will 'feel'. What this tweak does is remove the slight delay between *** on a menu and XP displaying the menu.
Type 'Regedit' then ###### 'Ok'
Find "HKEY_CURRENT_USER\Control Panel\Desktop\"
Select "MenuShowDelay"
Right ###### and select "Modify'
Reduce the number to around "100"
This is the delay time before a menu is opened. You can set it to "0" but it can make windows really hard to use as menus will open if you just look at them - well move your mouse over them anyway. I tend to go for anywhere between 50-150 depending on my mood
MAKE PROGRAMS LOAD FASTER
This little tweak tends to work for most programs. If your program doesn't load properly just undo the change. For any program:
Right-###### on the icon/shortcut you use to launch the program
Select properties
In the 'target' box, add ' /prefetch:1' at the end of the line.
###### "Ok"
Voila - your programs will now load faster.
IMPROVE XP SHUTDOWN SPEED
This tweak reduces the time XP waits before automatically closing any running programs when you give it the command to shutdown.
Go to Start then select Run
Type 'Regedit' and ###### ok
Find 'HKEY_CURRENT_USER\Control Panel\Desktop\'
Select 'WaitToKillAppTimeout'
Right ###### and select 'Modify'
Change the value to '1000'
###### 'OK'
Now select 'HungAppTimeout'
###### 'OK'
Now find 'HKEY_USERS\.DEFAULT\Control Panel\Desktop'
###### 'OK'
Now find 'HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\'
Select 'WaitToKillServiceTimeout'
###### 'OK'
SPEED UP BOOT TIMES I
This tweak works by creating a batch file to clear the temp and history folders everytime you shutdown so that your PC doesn't waste time checking these folders the next time it boots. It's quite simple to implement:
1. Open Notepad and create a new file with the following entries:
RD /S /q "C:\Documents and Settings\"UserName without quotes"\Local Settings\History"
RD /S /q "C:\Documents and Settings\Default User\Local Settings\History"
RD /S /q "D:\Temp\" <--"Deletes temp folder, type in the location of your temp folder"
2. Save the new as anything you like but it has to be a '.bat' file e.g. fastboot.bat or deltemp.bat
3. ###### 'Start' then 'Run'
4. Type in 'gpedit.msc' and hit 'ok'
5. ###### on 'Computer Configuration' then 'Windows Settings'
6. Double-###### on 'Scripts' and then on 'Shutdown'
7. ###### 'Add' and find the batch file that you created and then press 'Ok'
SPEED UP BOOT TIMES II
When your PC starts it usually looks for any bootable media in any floppy or cd-rom drives you have installed before it gets around to loading the Operating System from the HDD. This can waste valuable time. To fix this we need to make some changes to the Bios.
1. To enter the bios you usually press 'F2' or 'delete' when your PC starts
2. Navigate to the 'Boot' menu
3. Select 'Boot Sequence'
4. Then either move your Hard drive to the top position or set it as the 'First Device'
5. Press the 'Escape' key to leave the bios. Don't forget to save your settings before exiting
Note: Once this change has been made, you won't be able to boot from a floppy disc or a CD-rom. If for some strange reason you need to do this in the future, just go back into your bios, repeat the steps above and put your floppy or CD-rom back as the 'First Device'
SPEED UP BOOT TIMES III
When your computer boots up it usually has to check with the network to see what IP addresses are free and then it grabs one of these. By configuring a manually assigned IP address your boot time will improve. To do this do the following:
1. ###### on 'Start' and then ''Connect To/Show All Connections'
2. Right-###### your network adapter card and ###### 'Properties'.
3. On the 'General' tab, select 'TCP/IP' in the list of services and ###### 'Properties'
4.I n the TCP/IP properties, ###### 'Use the following address' and enter an IP address for your PC. If you are using a router this is usually 192.168.0.xx or 192.168.1.xx. If you are not sure what address you could check with your ISP or go to 'Start/run' and type 'cmd' and then 'ipconfig/all'. This will show your current IP settings which you will need to copy.
5. Enter the correct details for 'Subnet mask', 'Default gateway' and 'DNS Server'. Again if you are not sure what figures to enter use 'ipconfig/all' as in stage 4.
FREE UP MEMORY
I found this useful app via FixMyXP. ClearMem Is an Excellent Tool for speeding up your XP Computer (especially if your system has been on for awhile and you have a lot of applications open). What it does, is it Forces pages out of physical memory and reduces the size of running processes if working sets to a minimum. When you run this tool, the system pauses because of excessive high-priority activity associated with trimming the working sets. To run this tool, your paging file must be at least as large as physical memory. To Check your Paging File:
1. Go to your control panel, then ###### on 'System', then go to the 'Advanced' Tab, and Under 'Performance' ###### 'Settings' then the 'Advanced' Tab
2. On the Bottom you should see 'Virtual Memory' and a value. This is the value that must be at least as large as how much memory is in your system.
3. If the Virtual Memory Value is smaller than your system memory, ###### Change and change the Min Virtual Memory to a number that is greater than your total system memory, then ###### 'Set' and Reboot.
4. Once you have rebooted install ClearMem
ENSURE XP IS USING DMA MODE
XP enables DMA for Hard-Drives and CD-Roms by default on most ATA or ATAPI (IDE) devices. However, sometimes computers switch to PIO mode which is slower for data transfer - a typical reason is because of a virus. To ensure that your machine is using DMA:
1. Open 'Device Manager'
2. Double-###### 'IDE ATA/ATAPI Controllers'
3. Right-###### 'Primary Channel' and select 'Properties' and then 'Advanced Settings'
4. In the 'Current Transfer Mode' drop-down box, select 'DMA if Available' if the current setting is 'PIO Only'
ADD CORRECT NETWORK CARD SETTINGS
Some machines suffer from jerky graphics or high CPU usage even when a machine is idle. A possible solution for this, which, can also can help network performance is to:
1. RightClick 'My Computer'
2. Select 'Manage'
3. ###### on 'Device Manager'
4. DoubleClick your network adaptor under 'Network Adapters'
5. In the new window, select the 'Advanced' tab
6. Select 'Connection Type' and select the correct type for your card and then Reboot
REMOVE ANNOYING DELETE CONFIRMATION MESSAGES
Although not strictly a performance tweak I love this fix as it makes my machine 'feel' faster. I hate the annoying 'are you sure?' messages that XP displays, especially if I have to use a laptop touchpad to close them. To remove these messages:
1. Right-###### on the 'Recycle Bin' on the desktop and then ###### 'Properties'
2. Clear the 'Display Delete Confirmation Dialog' check box and ###### 'Ok'
If you do accidently delete a file don't worry as all is not lost. Just go to your Recycle Bin and 'Restore' the file.
DISABLE PREFETCH ON LOW MEMORY SYSTEMS
Prefetch is designed to speed up program launching by preloading programs into memory - not a good idea is memory is in short supply, as it can make programs hang. To disable prefetch:
1. ###### 'Start' then 'Run'
2. Type in 'Regedit' then ###### 'Ok'
3. Navigate to 'HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters\'
4. Right-###### on "EnablePrefetcher" and set the value to '0'
5. Reboot.
I HOPE THIS GUIDE WILL BE "STICKY"
You must have had some major time on your hands. Sweet stuff nonetheless. Kuddo's.
Just found this website and forum and printed out this list ... got to get to work :). I may have already done some of it, but I'll check thru and see.
I ***DO*** have a question, regarding MS Find Fast Indexing ... I went to the properties of each of my (logical) drives and unset the indexing. However, I find that there are Find Fast indexs still on the drives, in one case rather large. Can I safely delete these indexes now? (If I go into the control panel Find Fast section, it does not show any indexes.)
Thanks!!!!!!!
I only have one issue.
I always stop and start System Restore when I clean a computer to get rid of infected items, but it's helped me too many times to leave it off.
I guess I should add IMHO.
Again, thanks for the "script".
I like it!
very classic guide, straight to the point.
but I still have some fear of tweaking items that I really dont know. :(
Besides doing these things, what else would you do to a PC to speed it up?
I have I client who asked for me to speed up their PC, and what I usually do is: remove & clean viruses/spyware etc, defrag, change few settings (will do more now), run ccleaner and run Advanced System Care and then see how it goes.
That does not always seem to do the best job - what else would you suggest I do?
Thanks a lot,
John
Nice list I was thinking about making one of those. You saved me the time.
One to add is smartcard services. Unless you are at company that uses them it is not needed.
Depending on the computer secondary may be needed. I believe this is the one that gives you the "logon as" option.
I second that.... it may slow the system, but on a customer's PC, it can save hours of your labour or a O/S reload. For me, it's too valuable to miss.
I meet a tech once that depending on the type of virus or spyware he could leave it on because once the machine would not boot up. He had already turned it off and he needed to undo something that was related to a file. After he turned it off there were problems.
I think its one of those rare circumstances, I cant remember exactly why so my response is kind of vague.
hows this so far? some of the stuff in his post uses downloaded programs so i left those out
Code:
:: SPEEDUP FOLDER BROWSING:::::::::::::::::::::::::::::::
reg.exe add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v NoNetCrawling /t REG_DWORD /d 1 /f
:: DISABLE LAST ACCESS UPDATE
reg.exe add "HKCU\System\CurrentControlSet\Control\FileSystem" /v NtfsDisableLastAccessUpdate /t REG_DWORD /d 1 /f
:: IMPROVE BOOT TIMES
reg.exe add "HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction" /V Enable /t REG_SZ /d Y /f
:: REMOVE THE DESKTOP PICTURE
reg.exe ADD "HKCU\Control Panel\Colors" /V Background /t REG_SZ /d "0 0 0" /f
reg.exe ADD "HKCU\Control Panel\Desktop" /V TileWallpaper /t REG_SZ /d 0 /f
reg.exe ADD "HKCU\Control Panel\Desktop" /V WallpaperStyle /t REG_SZ /d 2 /f
reg.exe ADD "HKU\.Default\Control Panel\Colors" /V Background /t REG_SZ /d "0 0 0" /f
:: Show Menu Quicker
reg.exe add "HKCU\Control Panel\Desktop" /V MenuShowDelay /t REG_SZ /d 100 /f
::IMPROVE XP SHUTDOWN SPEED
reg.exe ADD "HKCU\Control Panel\Desktop" /V WaitToKillAppTimeout /t REG_SZ /d 1000 /f
reg.exe ADD "HKCU\Control Panel\Desktop" /V HungAppTimeout /t REG_SZ /d 1000 /f
reg.exe ADD "HKU\.DEFAULT\Control Panel\Desktop" /V WaitToKillAppTimeout /t REG_SZ /d 1000 /f
reg.exe ADD "HKLM\System\CurrentControlSet\Control" /V WaitToKillServiceTimeout /t REG_SZ /d 1000 /f
:: Delete Temp Files and Cookies
del /s /q "%userprofile%\cookies\*.*"
del /f /q %windir%\Temp\*.*
del /f /q "%userprofile%\local settings\temp\*.*"
del /f /q "%userprofile%\local settings\temporary internet files\*.*"
:: Disk Access Optimisations
reg.exe ADD "HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction" /V Enable /t REG_SZ /d N /f
reg.exe ADD "HKLM\Software\Microsoft\Windows\CurrentVersion\OptimalLayout" /V EnableAutoLayout /t REG_DWORD /d 0 /f
reg.exe ADD "HKLM\Software\System\CurrentControlSet\Control\FileSystem" /V NtfsDisableLastAccessUpdate /t REG_DWORD /d 1 /f
reg.exe ADD "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PrefetchParameters" /V EnablePrefetcher /t REG_DWORD /d 0 /f
:: Disable Services::::::::::::::::::::::::::::::::::::::
:: Alerter
sc config alerter start= disabled
:: Clipbook
sc config ClipSrv start= disabled
:: Computer Browser
sc config browser start= disabled
:: Distributed Link Tracking Client
sc config trkwks start= disabled
:: Fast User Switching
sc config FastUserSwitchingCompatibility start= disabled
:: Help and Support - (If you use Windows Help and Support leave this enabled)
sc config helpsvc start= disabled
:: Human Interface Access Devices
sc config hidserv start= disabled
:: Indexing Service
sc config CiSvc start= disabled
:: IPSEC Services
sc config PolicyAgent start= disabled
:: Messenger
sc config Messenger start= disabled
:: Netmeeting Remote Desktop Sharing (disabled for extra security)
sc config mnmsrvc start= disabled
:: Portable Media Serial Number
sc config WmdmPmSN start= disabled
:: Remote Desktop Help Session Manager (disabled for extra security)
sc config RDSessMgr start= disabled
:: Remote Procedure Call Locator
sc config RpcLocator start= disabled
:: Remote Registry (disabled for extra security)
sc config RemoteRegistry start= disabled
:: Secondary Logon
sc config seclogon start= disabled
:: Routing & Remote Access (disabled for extra security)
sc config RemoteAccess start= disabled
:: Server
sc config lanmanserver start= disabled
:: System Restore Service
::sc config srservice start= disabled
:: SSDP Discovery Service - (Unplug n' Pray will disable this)
sc config SSDPSRV start= disabled
:: Telnet
sc config TlntSvr start= disabled
:: TCP/IP NetBIOS Helper
sc config LmHosts start= disabled
:: Upload Manager
:: Universal Plug and Play Device Host
sc config upnphost start= disabled
:: Windows Time
sc config W32Time start= disabled
:: Wireless Zero Configuration (Do not disable if you use a wireless network)
:: sc config WZCSVC start= disabled
:: Workstation
sc config lanmanworkstation start= disabled
:: REBOOT!
shutdown.exe -r -t 5
The only thing left off that list, unless I missed it, was to remove programs that start up that don't need to be there. HP Updaters, Kodack Updates, Apple Updaters, you get the idea. Java, Adobe Speed Loader, Quicktime, etc.
i guess all the auto reg run entries and startup folder entries could be deleted but for some stuff like av youll still need so its kinda hard to determine which stays and goes from a batch file
Thanks for the information daynish. I will try these out on a test machine that i have. If it makes the computer faster than i am all for it.
Most of these should work for Vista right? You'd be surprised how many PCs I see running Vista on 512MB of RAM.
