Tech Savvy
- New Jersey
Hello fellow nibblers!
I’ve been racking my brain trying to get this setup correctly. The problem is the WiFi keeps dropping connection and for long periods of time (the WiFi is dropped more than it’s even active). The setup is pretty standard, but I’ll explain it in detail anyway:
Untangle UTM in router mode. Has 4 LAN ports:
- OUTSIDE - static ip from ISP
- INSIDE - 10.10.0.0/24 for all inside network devices (printers, computers, time clock tablet)
- VOIP - 10.20.0.0/24 for phones
- GUEST - 192.168.0.0/24 for guest WiFi
In addition to the physical interfaces I have VLANs setup:
VLAN ID 100 Bridges to INSIDE
VLAN ID 101 Bridges to VOIP
VLAN ID 102 Bridges to GUEST
currently firewall is left as defaults in order to simplify setup to rule out config problems on the Untangle.
DHCP is set up for each network on the untangle with the first 99 addresses removed from the pool for static assignment.
The wiring is like this (if I was on a computer I’d make a diagram, I need to do it anyway for documentation, but for now I think this will be okay.
Untangle
Port 1 (outside) cable modem
Port 2 (inside) unifi switch
Port 3 (VoIP) netgear dummy switch
Port 4 (guest) same unifi switch
This is the second time I’m using a unifi switch, so bear with me.
The unifi switch’s MGMT network is set to Corporate for the network 10.10.0.0/24
The unifi switch has VLAN Only networks for INSIDE(100) and GUEST(102)
The unifi switch’s management network is set to MGMT
The unifi switch has the following port assignments where the profile is in parentheses:
- 1 uplink to INSIDE (All)
- 1 uplink to GUEST (All)
- 1 cloud key (INSIDE)
- 3 APs (All)
- all other ports (INSIDE)
Originally I had the uplinks INSIDE/GUEST only but it wouldn’t work when I set them that way. Normally with a Cisco switch I set the uplinks as access ports since I have dedicated physical interfaces to the firewall.
The APs are set to broadcast 2 SSIDs, one for guest and one for inside.
I increased the DITM value to 3 to help with the time clock tablet (iPad)
Any change I make with the cloud key results in a never ending provisioning loop of the APs or switch, and will continue until i restart the cloud key, but even after restart and unplug of the cloud key, WiFi isn stable.
All computers hard wired into the unifi switch work fine.
Cables are new, shielded, and tested.
When WiFi isn’t working it keeps saying password is incorrect. Even though it definitely is correct. And that’s on either network, guest or inside.
No old APs on the network. Ive unplugged all APs except for one and problem still exists even after swapping cable and AP
I’m out of ideas and it’s going on day 3! What can I do? And if there is a unifi/untangle pro that wants to just take this mess off my hands and take it on as a sub please be my guest and pm me!
Sent from my iPhone using Tapatalk
Untangle
- 3 APs (All)
