Just wanted to post my specs on my system if anyone is also interested. Im pretty much up to date on everything but I really do hesitate on the upgrade as I really have a lot going on and do not want to lose it if it screws up. I have had that happen in the past and I cannot afford to be down.
System: Host: max Kernel: 4.13.15-041315-generic x86_64 (64 bit gcc: 7.2.0) Desktop: MATE 1.16.2 (Gtk 2.24.30)
Distro: Linux Mint 18.1 Serena
Machine: Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x Bios: American Megatrends v: 0504 date: 02/24/2017
CPU: Octa core AMD Ryzen 7 1800X Eight-Core (-HT-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 57488
clock speeds: max: 3600 MHz 1: 2200 MHz 2: 2200 MHz 3: 2200 MHz 4: 2200 MHz 5: 2200 MHz 6: 2200 MHz
7: 2200 MHz 8: 2200 MHz 9: 2200 MHz 10: 2200 MHz 11: 2200 MHz 12: 2200 MHz 13: 2200 MHz 14: 2200 MHz
15: 2200 MHz 16: 2200 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Device 67df bus-ID: 28:00.0
Display Server: X.Org 1.18.4 drivers: ati,amdgpu (unloaded: fbdev,vesa,radeon)
Resolution: 1920x1080@60.00hz
GLX Renderer: Gallium 0.4 on AMD POLARIS10 (DRM 3.18.0 / 4.13.15-041315-generic, LLVM 3.8.0)
GLX Version: 3.0 Mesa 12.0.6 Direct Rendering: Yes
Audio: Card-1 Advanced Micro Devices [AMD] Device 1457 driver: snd_hda_intel bus-ID: 2a:00.3
Card-2 Advanced Micro Devices [AMD/ATI] Device aaf0 driver: snd_hda_intel bus-ID: 28:00.1
Card-3 Logitech Webcam Pro 9000 driver: USB Audio usb-ID: 003-002
Sound: Advanced Linux Sound Architecture v: k4.13.15-041315-generic
Network: Card: Intel I211 Gigabit Network Connection driver: igb v: 5.4.0-k port: e000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 4250.9GB (31.2% used) ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB temp: 0C
ID-2: /dev/sdb model: ST2000DM006 size: 2000.4GB temp: 30C
ID-3: /dev/sdc model: ST2000DM006 size: 2000.4GB temp: 30C
Partition: ID-1: / size: 198G used: 17G (10%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 1.8T used: 1.2T (69%) fs: ext4 dev: /dev/md0
ID-3: swap-1 size: 34.28GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
RAID: Device-1: /dev/md0 - active components: online: sdb[1] sdc[0]
Info: raid: 1 report: 2/2 blocks: 1953383488 chunk size: N/A bitmap: true
Sensors: System Temperatures: cpu: N/A mobo: N/A gpu: 35.0
Fan Speeds (in rpm): cpu: 0
Info: Processes: 357 Uptime: 4 days Memory: 5082.6/32167.3MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481) inxi: 2.2.35
The 18.3 (Mate Desktop) Changes and additions can be read about on the Linux Mint Blog:
https://www.linuxmint.com/rel_sylvia_mate_whatsnew.php
Also how to do the upgrade right:
https://blog.linuxmint.com/?p=3462
