britechguy
- Staunton, VA
I had a new client yesterday, a local real estate agent, who now has two of these machines, one less than 5 years old that's running an i7-8th gen processor and the other only a couple of months old with an i7-13th gen (I think, it might be 12th).
In any case both of these machines have exhibited problems that I find very uncharacteristic in this class. She reports that the older one has problems with the trackpad just freezing up, but I could not replicate during the service call. The newer one has been freezing at random and, of course, would not do so for me.
I ran the HP support assistant on both and each of them needed a UEFI/BIOS update, which I got and applied. Afterward, I ran DISM/SFC, then, for "ultra-good measure" I did a Windows 11 Repair Install on both using the Windows 11 23H2 ISO freshly downloaded from Microsoft.
The newer one also appears to have a dead USB-C port, though it's old style USB-A port is just fine. The older one has both USB-A and USB-C ports functioning just fine.
I also encountered another "fun thing" with BitLocker, and that's that you cannot do a UEFI/BIOS update while it is active. The BIOS updater tells you this and that it will disable BitLocker before the update and re-enable it afterward, but they advise against doing this unless you have the BitLocker key, which we did not and which I could not find on the Microsoft Account for these laptops (both were using the same xxx@outlook.com address for the only account on the computer, which was, of course, also admin). I disabled BitLocker using manage-bde and left it off after having done the UEFI/BIOS update on each without issue.
I'm just waiting for a follow-up call, as I fear a nuke and pave will be necessary, but I did not want to go that route first. Just wondering if these machines have any sort of reputation I'm not aware of.
