MBAM/SAS/SpyBotSD 3-in-1 Portable App
I was under the impression that MBAM doesnt already make a portable version, due to the fact that the way it was designed to run and detect malware. Anyone else heard of this as well?
after opening help file on the program, now when i execute the program it opens the help window for spybot, will let you no if i fined the temp file coursing the problem
OK i give in any one no the file name that courses this or is it a reg entry:confused: it works fine on all outher systems untill i open the help file then it wont work just opens help window on all systems xp vista and 7 [B]Help[/B] :o
Here's the one built in XP. This seems like it may be the better build, especially since it is way smaller (66MB).
Testing I've done:
XP x86 / Win7 x86/ Win7 x64: Opened w/double click (no run as admin), all apps opened without error. Was also able to run all 3 simultaneously in each OS.
I'm obviously doing something stupid but I am having difficulty getting the software to run.
I infected my laptop with several Trojans/Virus/Fake AV and then tried to run the software from a USB drive. One of the bits of malware that I had downloaded immediately rebooted the laptop. On startup something calling itself 'Windows Problem Protector' appeared and proceeded to download and instal itself. This was followed by the inevitable screen telling me about all the bits of malware it had identified. I closed the window and explorer started up as normal however any attempts to run any .exe or.com file was blocked and the process terminated. I restarted into Safe Mode but the problem continued.
To clear the problem I used my Kaspersky10 boot disk to delete the fake AV but leave the rest in place. Now whenever I try and run MBAM-SAS-SpyBotSD the only item that appears is Bootsafe. No matter which option I select the laptop boots into normal mode. Even if I use the F key to go to Safe Mode and try again Bootsafe appears and again no matter which option I select it takes me to Normal Mode.
Any thoughts from anyone?
That is correct, and I have said it time and time again that Malwarebytes cannot be made portable, it has to be installed. Instead make a autoit script to install, update and perform a quick scan. I have written a autoit script that downloads the installation and update files stored on my server. Some infections may block you from downloading malwarebytes from common urls, so if the customers browser does not work then I instruct them to open a run box and type in the url address of the script located on my server and download it and run the script. Hey presto malwarebytes is up and running. This is about as portable you are going to get and works 95% of the time.
Heh, I forgot all about this. Saw it in the new posts and figured I'd update the build. It's still around the same size (75MB now) and I added CCleaner. I tested on XP, 7 x64 SP1, and 7 x86. Still opens quick as build 2.
http://www.mediafire.com/?ym1zd54avvaqe9p
Added link to original post also.
Just to inform you, AVG flagged "your" program(s). [the latest build at the time of this post]
Here's what AVG had to say:
""MBAM-SAS-SpyBotSD-CCleaner.exe"
"Trojan horse Generic21.JNT"
Just for poops and giggles, I scanned it with SAS and MBAM, haha, needless to say they didn't complain :P
Do you know why AVG threw a fit? Or is it just because it's an oddly named .EXE with (possibly) scrambled innards?
Awesome idea and thank you for your hard work, lookin' forward to your future advancements in this project!
It's the way Cameyo virtualizes and builds the package. I had a coworker say MSE 1 nabbed it up one time, but MSE 2 and Avast 4/5 didn't complain.
As before, this is strictly a Ninite setup of the apps captured with Cameyo. It's rather easy and anyone could make their own custom package in a VM or spare machine.
http://www.cameyo.com/
http://www.ninite.com/
Is anyone else successfully still using this? It was a great app when it worked, but now for some reason even the original posted version has stopped working for me.
