MacBook Pro A1706 - USB accessories disabled
Rigo
Australia
Received this laptop with a weird error message at startup:
Unplug the accessory using too much power to re-enable USB devices
There's nothing even a mouse plugged in except the power adapter.
It appears the battery though deemed normal is not holding charge once the power adapter is disconnected.
Could high power feed from totally depleted battery from the adapter trigger the problem?
One of the right side USB ports appears to be disabled/not working.
A little googling suggested I might get a clue from the USB log as below but I can't see anything relatable here:
Last login: Sat Aug 9 18:32:26 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
Lauras-MBP-2:~ XXXXXXXXX$ log stream -predicate 'eventMessage contains "USB"' -info
Filtering the log data using "composedMessage CONTAINS "USB""
Timestamp Thread Type Activity PID TTL
2025-08-11 10:03:44.945953+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIRequest: AppleUSBXHCIRequest::finish: transfer completed with status 0xe00002ed
2025-08-11 10:03:45.041594+1000 0x1c2 Default 0x0 0 0 kernel: (IOUSBHostFamily) HS09@14600000: AppleUSBHostPort::terminateDevice: destroying 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM)): connect change interrupt
2025-08-11 10:03:45.043086+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:1011][0x100008ba3] CompleteInReport:0xe00002ed
2025-08-11 10:03:45.043111+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:798][0x100008ba3] Schedule retry reason:0xe00002ed count:9 deadline:50ms
2025-08-11 10:03:45.046045+1000 0x9777e Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service removed: IOHIDService name: id:0x100008ba9 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:0 batchInterval:1 events:6378 mask:0x20045 {
Button = 1;
NULL = 1;
Pointer = 6333;
Scroll = 43;
2025-08-11 10:03:45.044361+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008ba3:force close (IOUSBHostInterface-0x100008ba1)
2025-08-11 10:03:45.044447+1000 0x98356 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:469][0x100008ba3] Close interface: 0x100008ba1 0x0
2025-08-11 10:03:45.044487+1000 0x98356 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:137][0x100008ba3] Stop: 0x0
2025-08-11 10:03:45.044550+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserHIDEventDriver-0x100008ba9:force close (AppleUserUSBHostHIDDevice-0x100008ba3)
2025-08-11 10:03:45.045505+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008ba3 stop
2025-08-11 10:03:45.045524+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008ba3 handleStop src: 0 srfc: 0 srtc: 0 srt: 0 grc: 0 grfc: 0 grtc: 0 grt: 0 irc: 6373 irt: 19869536325597
2025-08-11 10:04:27.204788+1000 0x988c3 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:04:27.781507+1000 0x986e1 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:07:12.542896+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIDevice: AppleUSBXHCIDevice::transferEvent: no endpoint 1 for event 0x000000000029e600 1b000000 04018001
2025-08-11 10:07:12.607565+1000 0x911f2 Default 0x0 0 0 kernel: (IOUSBHostFamily) HS09@14600000: AppleUSBHostPort::enumerateDeviceComplete_block_invoke: enumerated 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM) / 4) at 1.5 Mbps
2025-08-11 10:07:12.607586+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:07:12.607591+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:07:12.607596+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (Microsoft 5-Button Mouse with IntelliEye(TM)) options 0x00000000
2025-08-11 10:07:12.607609+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:07:12.607612+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostDevice <private> (Microsoft 5-Button Mouse with IntelliEye(TM))
2025-08-11 10:07:12.607625+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::addDeviceToUsbPlane:
2025-08-11 10:07:12.607928+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:07:12.607938+1000 0x914b4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering Microsoft 5-Button Mouse with IntelliEye(TM)@14600000 (<private>) for matching
2025-08-11 10:07:12.612089+1000 0x97e7e Default 0x0 101 0 kernelmanagerd: Received kext load notification: com.apple.driver.AppleUSBAudio
2025-08-11 10:07:12.672724+1000 0x99bbb Default 0x0 0 0 kernel: (IOUSBHostFamily) Microsoft 5-Button Mouse with IntelliEye(TM)@14600000: IOUSBHostDevice::setConfigurationGated: AppleUSBHostCompositeDevice selected configuration 1
2025-08-11 10:07:12.673605+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:07:12.673618+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:07:12.673622+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (IOUSBHostInterface) options 0x00000000
2025-08-11 10:07:12.674049+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:07:12.674063+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostInterface <private> (IOUSBHostInterface)
2025-08-11 10:07:12.674399+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:07:12.674496+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering AppleUSBInterface@0 (<private>) for matching
2025-08-11 10:07:12.674975+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:07:12.675723+1000 0x5b2 Error 0x0 232 0 com.apple.ifdreader: [com.apple.CryptoTokenKit:ccid] Failed to find AppleUSBAlternateServiceRegistryID.
2025-08-11 10:07:12.677976+1000 0x99bc0 Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008bef using existing server IOUserServer(com.apple.driverkit.AppleUserHIDDrivers-0x100007b49)-0x100007b50
2025-08-11 10:07:12.678014+1000 0x99bc0 Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef start (state:0x0)
2025-08-11 10:07:12.678991+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:555][0x100008bef] Open interface: 0x100008bed
2025-08-11 10:07:12.682110+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:712][0x100008bef] HID descriptor interface:0 index:0 length:72 72 72
2025-08-11 10:07:12.682300+1000 0x980d3 Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef start (state:0x4)
2025-08-11 10:07:12.682308+1000 0x980d3 Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef start
2025-08-11 10:07:12.682963+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:343][0x100008bef] inPipe:1 inputReportSize:4 inMaxPacketSize:4 inBufferSize:4
2025-08-11 10:07:12.682976+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:386][0x100008bef] outPipe:0 outMaxPacketSize:0
2025-08-11 10:07:12.683591+1000 0x980d3 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:126][0x100008bef] Start ret: 0x0
2025-08-11 10:07:12.683623+1000 0x99bc0 Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008bef::start(IOUSBHostInterface-0x100008bed) ok
2025-08-11 10:07:12.686519+1000 0x99bc2 Fault 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef Matching has vendor DeviceUsagePage : ff0c bundleIdentifier com.apple.AppleUserHIDDrivers ioclass AppleUserHIDEventService but transport and vendorID is missing
2025-08-11 10:07:12.709060+1000 0x994eb Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service added: IOHIDService name:AppleUserHIDEventDriver id:0x100008bf5 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:8000 batchInterval:0 events:0 mask:0x0
2025-08-11 10:08:12.865991+1000 0x99bbd Default 0x0 101 0 kernelmanagerd: Received kext unload notification: com.apple.driver.AppleUSBAudio
2025-08-11 10:09:19.651371+1000 0x99f76 Default 0x0 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:process] Periodic Run States <RBProcessState| identity:app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> role:UserInteractiveFocal gpuRole:UserInteractiveFocal explicitJetsamBand:100 memoryLimit:Inactive(Soft) flags:60 guaranteedRunning:NO legacyFinishTaskReason:0 inheritances:<RBMutableInheritanceCollection| inheritancesByEnvironment:{
}> attributes:[
SupportsBackgroundAudio
] primitiveAssertions:[
<RBSProcessAssertionInfo| type:2 reason:0 name:"Domain" domain:"com.apple.appnap:AppDrawing" expl:"AppDrawing">,
<RBSProcessAssertionInfo| type:2 reason:20242 name:"Domain" domain:"com.apple.appnap:AppVisible" expl:"AppVisible">,
<RBSProcessAssertionInfo| type:2 reason:10000 name:"Domain" domain:"com.apple.fuseboard:Frontmost" expl:"FUSBFrontmostProcess">,
<RBSProcessAssertionInfo| type:2 reason:20247 name:"Domain" domain:"com.apple.launchservicesd:RoleUserInteractiveFocal" expl:"frontmost:27199">,
<RBSProcessAssertionInfo| type:2 reason:20248 name:"Domain" domain:"com.apple.launchservicesd:Ro<…>
2025-08-11 10:09:19.651518+1000 0x99f76 Default 0x0 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:process] Periodic Run States <RBProcessState| identity:app<application.com.getdropbox.dropbox.7356767.58817007(501)> role:UserInteractive gpuRole:UserInteractive explicitJetsamBand:100 memoryLimit:Inactive(Soft) flags:60 guaranteedRunning:NO legacyFinishTaskReason:0 inheritances:<RBMutableInheritanceCollection| inheritancesByEnvironment:{
}> attributes:[
<RBSProcessAssertionInfo| type:2 reason:10000 name:"Domain" domain:"com.apple.fuseboard:Visible" expl:"FUSBProcessWindowState: visible">,
<RBSProcessAssertionInfo| type:2 reason:20246 name:"Domain" domain:"com.apple.launchservicesd:RoleUserInteractive" expl:"uielement:1935">
2025-08-11 10:09:21.297446+1000 0x97e5b Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 0 times]
2025-08-09 14:11:14.883628+0000 0x82 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 0 times]
2025-08-11 10:10:20.309392+1000 0x9a209 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 2/7. ID:150-143-20746 Explanation:"FUSBFrontmostProcess" Attributes:
"<RBSDomainAttribute| domain:\"com.apple.fuseboard\" name:\"Frontmost\" sourceEnvironment:\"(null)\">",
"<RBSAcquisitionCompletionAttribute| policy:AfterApplication>"
2025-08-11 10:10:20.309742+1000 0x9a209 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 6/7. ID:150-143-20751 Explanation:"FUSBProcessWindowState: visible" Attributes:
"<RBSDomainAttribute| domain:\"com.apple.fuseboard\" name:\"Visible\" sourceEnvironment:\"(null)\">",
2025-08-11 10:10:20.310861+1000 0x9a209 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.getdropbox.dropbox.7356767.58817007(501)> assertion details 2/3. ID:150-143-20088 Explanation:"FUSBProcessWindowState: visible" Attributes:
2025-08-11 10:10:20.390069+1000 0x9a1a4 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 2 times]
2025-08-09 14:12:13.946221+0000 0x115 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 2 times]
2025-08-11 10:10:20.894000+1000 0x9a220 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 117 times]
2025-08-09 14:12:14.446442+0000 0x115 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 124 times]
2025-08-11 10:10:21.789373+1000 0x97f56 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer [Repeated 47 times]
2025-08-11 10:10:21.789383+1000 0x97f56 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: <private>
2025-08-11 10:10:21.795909+1000 0x7a Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: <private>
2025-08-09 14:12:15.316324+0000 0x8f Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer [Repeated 40 times]
2025-08-11 10:10:21.798984+1000 0x97f56 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: <private>
2025-08-09 14:12:15.316360+0000 0x8f Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-11 10:10:21.801340+1000 0x7a Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: <private>
2025-08-11 10:10:21.802791+1000 0x97f34 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private>
2025-08-09 14:12:15.320900+0000 0x82 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-09 14:12:15.325318+0000 0x8f Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-09 14:12:15.326367+0000 0x1ab Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-09 14:12:15.356820+0000 0x82 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-11 10:10:22.318773+1000 0x97f34 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 8 times]
2025-08-09 14:12:15.873857+0000 0x1ab Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 8 times]
2025-08-11 10:10:22.846607+1000 0x97f34 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 10 times]
2025-08-09 14:12:16.404939+0000 0x115 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 10 times]
2025-08-11 10:10:29.036491+1000 0x9a24b Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer [Repeated 4 times]
2025-08-11 10:10:29.036506+1000 0x9a24b Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: <private>
2025-08-11 10:10:29.043235+1000 0x7a Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: <private>
2025-08-09 14:12:22.562561+0000 0x8f Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer [Repeated 4 times]
2025-08-09 14:12:22.562597+0000 0x8f Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 4294967295): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-09 14:12:22.567274+0000 0x1ab Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 1): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-11 10:10:29.094361+1000 0x9a220 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private>
2025-08-09 14:12:22.620792+0000 0x94 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000
2025-08-11 10:11:39.815738+1000 0x9a60b Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:11:40.381249+1000 0x9a4a0 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:12:01.217474+1000 0x9a729 Info 0x78b24 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:general] _executablePath = /usr/libexec/USBAgent
2025-08-11 10:12:01.218270+1000 0x9a729 Default 0x78b24 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:process] Resolved pid 25771 to [osservice<com.apple.USBAgent(501)>:25771]
2025-08-11 10:12:01.224157+1000 0x9a729 Default 0x78b24 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:process] [osservice<com.apple.USBAgent(501)>:25771] Memory Limits: active 0 inactive 0
<private>
2025-08-11 10:12:01.224308+1000 0x9a729 Default 0x78b24 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:process] [osservice<com.apple.USBAgent(501)>:25771] This process will not be managed.
2025-08-11 10:12:34.322829+1000 0x9a220 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 0 times]
2025-08-09 14:14:27.878105+0000 0x1ab Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 0 times]
2025-08-11 10:13:42.682459+1000 0x9a220 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 0 times]
2025-08-09 14:15:36.237296+0000 0x1ab Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 0 times]
2025-08-11 10:15:47.251944+1000 0x9abc9 Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 8 times]
2025-08-09 14:17:40.808818+0000 0x94 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 8 times]
2025-08-11 10:18:52.390546+1000 0x9b555 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:18:52.958702+1000 0x9b54e Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:20:26.478382+1000 0x9b8b5 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 2/7. ID:150-143-20746 Explanation:"FUSBFrontmostProcess" Attributes:
2025-08-11 10:20:26.478722+1000 0x9b8b5 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 6/7. ID:150-143-20751 Explanation:"FUSBProcessWindowState: visible" Attributes:
2025-08-11 10:20:26.479746+1000 0x9b8b5 Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.getdropbox.dropbox.7356767.58817007(501)> assertion details 2/3. ID:150-143-20088 Explanation:"FUSBProcessWindowState: visible" Attributes:
2025-08-11 10:24:01.181427+1000 0x9bffd Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 8 times]
2025-08-09 14:25:54.809730+0000 0x94 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 8 times]
2025-08-11 10:26:04.966507+1000 0x9c3cf Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:26:05.534915+1000 0x9c372 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:29:37.134668+1000 0x9bffd Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 0 times]
2025-08-09 14:31:30.702322+0000 0x115 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 0 times]
2025-08-11 10:30:32.534848+1000 0x9cbdf Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 2/7. ID:150-143-20746 Explanation:"FUSBFrontmostProcess" Attributes:
2025-08-11 10:30:32.535163+1000 0x9cbdf Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.apple.Terminal.1152921500311912225.1152921500311912230(501)> assertion details 6/7. ID:150-143-20751 Explanation:"FUSBProcessWindowState: visible" Attributes:
2025-08-11 10:30:32.536254+1000 0x9cbdf Info 0x1f5 150 0 runningboardd: (RunningBoard) [com.apple.runningboard:assertion] app<application.com.getdropbox.dropbox.7356767.58817007(501)> assertion details 2/3. ID:150-143-20088 Explanation:"FUSBProcessWindowState: visible" Attributes:
2025-08-11 10:31:41.332235+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIRequest: AppleUSBXHCIRequest::finish: transfer completed with status 0xe00002ed
2025-08-11 10:31:41.428778+1000 0x1c2 Default 0x0 0 0 kernel: (IOUSBHostFamily) HS09@14600000: AppleUSBHostPort::terminateDevice: destroying 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM)): connect change interrupt
2025-08-11 10:31:41.430360+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:1011][0x100008bef] CompleteInReport:0xe00002ed
2025-08-11 10:31:41.430397+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:798][0x100008bef] Schedule retry reason:0xe00002ed count:9 deadline:50ms
2025-08-11 10:31:41.431701+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008bef:force close (IOUSBHostInterface-0x100008bed)
2025-08-11 10:31:41.431848+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserHIDEventDriver-0x100008bf5:force close (AppleUserUSBHostHIDDevice-0x100008bef)
2025-08-11 10:31:41.431943+1000 0x9ce2f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:469][0x100008bef] Close interface: 0x100008bed 0x0
2025-08-11 10:31:41.432024+1000 0x9ce2f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:137][0x100008bef] Stop: 0x0
2025-08-11 10:31:41.432588+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef stop
2025-08-11 10:31:41.432854+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008bef handleStop src: 0 srfc: 0 srtc: 0 srt: 0 grc: 0 grfc: 0 grtc: 0 grt: 0 irc: 2410 irt: 21398077622290
2025-08-11 10:31:41.433539+1000 0x9cb28 Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service removed: IOHIDService name: id:0x100008bf5 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:8000 batchInterval:0 events:2418 mask:0x20041 {
NULL = 1;
Pointer = 2165;
Scroll = 252;
2025-08-11 10:31:53.694378+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIDevice: AppleUSBXHCIDevice::transferEvent: no endpoint 1 for event 0x00000000002e0b00 1b000000 05018001
2025-08-11 10:31:53.704978+1000 0x90fe4 Default 0x0 0 0 kernel: (IOUSBHostFamily) HS06@14300000: AppleUSBHostPort::enumerateDeviceComplete_block_invoke: enumerated 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM) / 5) at 1.5 Mbps
2025-08-11 10:31:53.705025+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:31:53.705039+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:31:53.705050+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (Microsoft 5-Button Mouse with IntelliEye(TM)) options 0x00000000
2025-08-11 10:31:53.705094+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:31:53.705113+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostDevice <private> (Microsoft 5-Button Mouse with IntelliEye(TM))
2025-08-11 10:31:53.705164+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::addDeviceToUsbPlane:
2025-08-11 10:31:53.705935+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:31:53.705967+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering Microsoft 5-Button Mouse with IntelliEye(TM)@14300000 (<private>) for matching
2025-08-11 10:31:53.713184+1000 0x9d017 Default 0x0 101 0 kernelmanagerd: Received kext load notification: com.apple.driver.AppleUSBAudio
2025-08-11 10:31:53.773969+1000 0x9d015 Default 0x0 0 0 kernel: (IOUSBHostFamily) Microsoft 5-Button Mouse with IntelliEye(TM)@14300000: IOUSBHostDevice::setConfigurationGated: AppleUSBHostCompositeDevice selected configuration 1
2025-08-11 10:31:53.775031+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:31:53.775060+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:31:53.775071+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (IOUSBHostInterface) options 0x00000000
2025-08-11 10:31:53.775356+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:31:53.775371+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostInterface <private> (IOUSBHostInterface)
2025-08-11 10:31:53.775925+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:31:53.776445+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering AppleUSBInterface@0 (<private>) for matching
2025-08-11 10:31:53.777456+1000 0x9ce2e Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:31:53.778706+1000 0x5b2 Error 0x0 232 0 com.apple.ifdreader: [com.apple.CryptoTokenKit:ccid] Failed to find AppleUSBAlternateServiceRegistryID.
2025-08-11 10:31:53.782214+1000 0x9d01c Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008c2f using existing server IOUserServer(com.apple.driverkit.AppleUserHIDDrivers-0x100007b49)-0x100007b50
2025-08-11 10:31:53.782251+1000 0x9d01c Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f start (state:0x0)
2025-08-11 10:31:53.783123+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:555][0x100008c2f] Open interface: 0x100008c2d
2025-08-11 10:31:53.785597+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:712][0x100008c2f] HID descriptor interface:0 index:0 length:72 72 72
2025-08-11 10:31:53.785813+1000 0x9c7a0 Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f start (state:0x4)
2025-08-11 10:31:53.785826+1000 0x9c7a0 Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f start
2025-08-11 10:31:53.786771+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:343][0x100008c2f] inPipe:1 inputReportSize:4 inMaxPacketSize:4 inBufferSize:4
2025-08-11 10:31:53.786790+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:386][0x100008c2f] outPipe:0 outMaxPacketSize:0
2025-08-11 10:31:53.787347+1000 0x9c7a0 Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:126][0x100008c2f] Start ret: 0x0
2025-08-11 10:31:53.787367+1000 0x9d01c Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008c2f::start(IOUSBHostInterface-0x100008c2d) ok
2025-08-11 10:31:53.789873+1000 0x9d01e Fault 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f Matching has vendor DeviceUsagePage : ff0c bundleIdentifier com.apple.AppleUserHIDDrivers ioclass AppleUserHIDEventService but transport and vendorID is missing
2025-08-11 10:31:53.810574+1000 0x9cb28 Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service added: IOHIDService name:AppleUserHIDEventDriver id:0x100008c35 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:8000 batchInterval:0 events:0 mask:0x0
2025-08-11 10:32:06.665905+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIRequest: AppleUSBXHCIRequest::finish: transfer completed with status 0xe00002ed
2025-08-11 10:32:06.763665+1000 0x1bc Default 0x0 0 0 kernel: (IOUSBHostFamily) HS06@14300000: AppleUSBHostPort::terminateDevice: destroying 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM)): connect change interrupt
2025-08-11 10:32:06.765322+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:1011][0x100008c2f] CompleteInReport:0xe00002ed
2025-08-11 10:32:06.765360+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:798][0x100008c2f] Schedule retry reason:0xe00002ed count:9 deadline:50ms
2025-08-11 10:32:06.766698+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008c2f:force close (IOUSBHostInterface-0x100008c2d)
2025-08-11 10:32:06.766788+1000 0x9d19a Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:469][0x100008c2f] Close interface: 0x100008c2d 0x0
2025-08-11 10:32:06.766833+1000 0x9d19a Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:137][0x100008c2f] Stop: 0x0
2025-08-11 10:32:06.766914+1000 0x6f Default 0x0 0 0 kernel: DK: AppleUserHIDEventDriver-0x100008c35:force close (AppleUserUSBHostHIDDevice-0x100008c2f)
2025-08-11 10:32:06.767824+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f stop
2025-08-11 10:32:06.768253+1000 0x9ce32 Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service removed: IOHIDService name: id:0x100008c35 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:8000 batchInterval:0 events:215 mask:0x20001 {
NULL = 1;
Pointer = 214;
2025-08-11 10:32:06.767847+1000 0x6f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c2f handleStop src: 0 srfc: 0 srtc: 0 srt: 0 grc: 0 grfc: 0 grtc: 0 grt: 0 irc: 213 irt: 21633251364724
2025-08-11 10:32:34.441857+1000 0x9bffd Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 0 times]
2025-08-09 14:34:28.102134+0000 0x115 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 0 times]
2025-08-11 10:32:51.666251+1000 0x9bffd Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 16 times]
2025-08-09 14:34:45.324878+0000 0x82 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 16 times]
2025-08-11 10:32:56.465748+1000 0x9bffd Default 0x0 0 0 kernel: (KernelRelayHost) _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: <private> [Repeated 7 times]
2025-08-09 14:34:50.127143+0000 0x82 Default 0x0 0 0 kernel: (KernelRelayDevice) [iBridge]: _sendCommandGated (ep: 3): Sending USB buffer size: 17408 command: 0x8026f000 [Repeated 7 times]
2025-08-11 10:33:06.832275+1000 0x9d017 Default 0x0 101 0 kernelmanagerd: Received kext unload notification: com.apple.driver.AppleUSBAudio
2025-08-11 10:33:17.542292+1000 0x9da4f Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:33:18.113477+1000 0x9d990 Default 0x0 215 0 airportd: (IO80211) [com.apple.WiFiManager:] SC: <airport[215]> airportdProcessSystemConfigurationEvent: Processing 'State:/Network/Interface/en0/AirPort/SmartCCADesenseUSBPresence'
2025-08-11 10:34:40.303656+1000 0xdb Error 0x0 0 0 kernel: (AppleUSBXHCI) AppleUSBXHCIDevice: AppleUSBXHCIDevice::transferEvent: no endpoint 1 for event 0x00000000002e0900 1b000000 06018001
2025-08-11 10:34:40.369939+1000 0x90fe4 Default 0x0 0 0 kernel: (IOUSBHostFamily) HS09@14600000: AppleUSBHostPort::enumerateDeviceComplete_block_invoke: enumerated 0x045e/0039/0300 (Microsoft 5-Button Mouse with IntelliEye(TM) / 6) at 1.5 Mbps
2025-08-11 10:34:40.369973+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:34:40.369980+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:34:40.369986+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (Microsoft 5-Button Mouse with IntelliEye(TM)) options 0x00000000
2025-08-11 10:34:40.370014+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:34:40.370025+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostDevice <private> (Microsoft 5-Button Mouse with IntelliEye(TM))
2025-08-11 10:34:40.370051+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::addDeviceToUsbPlane:
2025-08-11 10:34:40.370657+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:34:40.370691+1000 0x9cfe4 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering Microsoft 5-Button Mouse with IntelliEye(TM)@14600000 (<private>) for matching
2025-08-11 10:34:40.375442+1000 0x9d925 Default 0x0 101 0 kernelmanagerd: Received kext load notification: com.apple.driver.AppleUSBAudio
2025-08-11 10:34:40.436591+1000 0x9e3e7 Default 0x0 0 0 kernel: (IOUSBHostFamily) Microsoft 5-Button Mouse with IntelliEye(TM)@14600000: IOUSBHostDevice::setConfigurationGated: AppleUSBHostCompositeDevice selected configuration 1
2025-08-11 10:34:40.437827+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: controller <private> (XHC1) usbServiceArray <private>(count 1) options 0x00000000
2025-08-11 10:34:40.437854+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallback: [0] <private>
2025-08-11 10:34:40.437863+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: controller <private> (XHC1) usbService <private> (IOUSBHostInterface) options 0x00000000
2025-08-11 10:34:40.437905+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:34:40.437918+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCallGated: IOUSBHostInterface <private> (IOUSBHostInterface)
2025-08-11 10:34:40.439171+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: usbServiceCallbackGated completed with 0x00000000 and service <private>
2025-08-11 10:34:40.439199+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::usbServiceCall: registering AppleUSBInterface@0 (<private>) for matching
2025-08-11 10:34:40.440156+1000 0x98355 Error 0x0 0 0 kernel: (IOUSBFamily) AppleUSBLegacyRoot@(null): AppleUSBLegacyRoot::getOrCreateLegacyControllerGated: located existing AppleUSBController@14000000
2025-08-11 10:34:40.441366+1000 0x5b2 Error 0x0 232 0 com.apple.ifdreader: [com.apple.CryptoTokenKit:ccid] Failed to find AppleUSBAlternateServiceRegistryID.
2025-08-11 10:34:40.444774+1000 0x9e3eb Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008c4d using existing server IOUserServer(com.apple.driverkit.AppleUserHIDDrivers-0x100007b49)-0x100007b50
2025-08-11 10:34:40.444812+1000 0x9e3eb Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c4d start (state:0x0)
2025-08-11 10:34:40.445690+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:555][0x100008c4d] Open interface: 0x100008c4b
2025-08-11 10:34:40.448403+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:712][0x100008c4d] HID descriptor interface:0 index:0 length:72 72 72
2025-08-11 10:34:40.448654+1000 0x9d03f Default 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c4d start (state:0x4)
2025-08-11 10:34:40.448669+1000 0x9d03f Info 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c4d start
2025-08-11 10:34:40.449753+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:343][0x100008c4d] inPipe:1 inputReportSize:4 inMaxPacketSize:4 inBufferSize:4
2025-08-11 10:34:40.449782+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [IOUserUSBHostHIDDevice.cpp:386][0x100008c4d] outPipe:0 outMaxPacketSize:0
2025-08-11 10:34:40.450456+1000 0x9d03f Default 0x0 0 0 kernel: (com.apple.AppleUserHIDDrivers.dext) [AppleUserUSBHostHIDDevice.cpp:126][0x100008c4d] Start ret: 0x0
2025-08-11 10:34:40.450480+1000 0x9e3eb Default 0x0 0 0 kernel: DK: AppleUserUSBHostHIDDevice-0x100008c4d::start(IOUSBHostInterface-0x100008c4b) ok
2025-08-11 10:34:40.453435+1000 0x9e3ed Fault 0x0 0 0 kernel: (IOHIDFamily) AppleUserUSBHostHIDDevice:0x100008c4d Matching has vendor DeviceUsagePage : ff0c bundleIdentifier com.apple.AppleUserHIDDrivers ioclass AppleUserHIDEventService but transport and vendorID is missing
2025-08-11 10:34:40.473488+1000 0x9e1b7 Default 0x0 143 0 WindowServer: (IOKit) [com.apple.iohid:default] Service added: IOHIDService name:AppleUserHIDEventDriver id:0x100008c53 primaryUsagePage:0x1 primaryUsage:0x2 transport:USB reportInterval:8000 batchInterval:0 events:0 mask:0x0
Any input appreciated
FYI using the A number isn't near as useful as the serial number. In this case the code represents 7 different models sold over a 9 month period.
Have you had a good look at the USB ports to make sure there's no damage? Have you flashed the pram and reset nvram? Since it's an Intel box you should be able to boot from a Linux stick. Shutdown the computer, plug in the stick, power up holding the option key down. It should boot to a screen showing available boot devices of which one would be the Linux. If it doesn't try it again but with a an external keyboard. Option key is the Alt key.
Noted 😏
SN: C02W2KYFHV2L
I'll the options you're suggesting
this is a 2017 4 thunderbolt port model, MacBook Pro 13", have you oppened and checked the usb c ports for damage? if no damage, do you have any replacements to test? it can very well be a Logic board issue.
Another thing you can check is it this is a MDM machine with security settings activated that disabled the usb c ports
