HFultzjr
- Central PA, USA
Ok, so I've been working on this one for a while (friend).
Here is how the computer came in:
Acer Desktop (don't have the model number in front of me)
4 GB Ram
AMD Quad-Core
750 GB WD Blue Drive
CD/DVD Writer
Multiple card reader
Win 7 fully updated and patched
Random BSOD (mostly video driver issues)...I think I've got these resolved.
Update Video drivers and removed minor adware/junkware.
Hard drive and other hardware including Ram tested ok, except the voltage on the CMOS battery was only 2.4 volts.
Replaced CMOS battery and now I'm stuck with this.:
The main issue is CMOS will not store any changes from defaults.
Computer boots, runs hardware check and stops at:
CMOS checksum error or CMOS battery loss occurs.
Press F1 to continue or Esc to enter BIOS.
I enter BIOS and the Date/Time is only thing I need changed.
Change Date/Time....save....reboot......same thing.
If I hit F1 it loads normal, except Date/Time is wrong.
I just can't seem to get the settings changed from the defaults.
Here is what I've tried:
New battery....several
Checked battery voltage.....3.2 volts
Cleaned battery contacts
Left battery out overnight to reset
Reset by switching the jumper
Tried without battery
Flashed BIOS (no upgrade was available) (successful)
Checked for bulging caps or other issues on board.
Checked, removed, replaced and ran memtest (16 hours) on Ram
Removed everything from board except, ram, keyboard and mouse, monitor....same issue
Noted that I get no beeps when RAM or other hardware removed
Replaced power supply with known good one.
Computer still boots to F1 or Esc. Reset bios time....same thing
It seems the CMOS will not retain any settings, but always goes back to the default.
Computer runs normal after booting windows and changing the time each time it starts. Ran for 2 days with no issues or BSOD.....nothing, until I shutdown and re-start. Then same issue all over again
One other issue. Sometimes I need to restart several times, to get to the message. Computer starts, fans spin, but it goes no further. Restart several times until I get to the F1 or Esc. message.
If computer is "restarted" no issues with Date/Time in windows. It is only when a complete shutdown is done, that issue pops up.
Restart numerous times.... no issue....only when completely shutdown and then restarted.
I'm sure I've missed some things I've tried (Googled my head out).
What am I missing....changed the battery and this happens. Battery change took less than a minute.
Does same thing with old battery also.
I know this is a lot to read through, but I can only come up with the board is now bad.....did I cause this?
The way I have this now is:
Computer boots to F1 or Esc.
Press F1
Windows boots
I have a start/run entry to auto run an internet time synch program
Wait about 30 seconds, time synchs, everything is fine until next shutdown.
Thanks for listening,
Harold
4 GB Ram
AMD Quad-Core
CD/DVD Writer
Press F1
Windows boots
Harold
