Romaniac
- Denver and Seattle
Laptop not charging; power jack? (mobo/jack pics)
Hey all and thanks for reading. I have what seems like a 'toughy'.
Gateway M-6827 Laptop
Background:
Client tripped over the charger, and the laptop ran on battery for a while (battery was not charged too much/not the greatest fitness), then shut off due to assumed drained battery.
Could not charge laptop afterwards.
Also mentioned that even before this incident, he had to fiddle with the charger tip in the charging port to make it charge/keep charging. This latest 'trip over' was the last straw, I guessed.
What I tried:
Took battery out, drained power; used a spare charger with interchangeable tips, and used matching tip Didn't charge and charging light (front of laptop) did not come on (charger is confirmed working).
Poked the 'tip' of DC port, and it is sturdy.
I just took the laptop apart (quite a it of a challenge due to design). And then I see the jack - it appears fine...?!
If I did my homework, the silver wire on the back side should be damaged. Though it looks a little off in the pictures it seems solid.
Need help! and thanks for any advice!
Underside of PCB, under jack.
Hmmm, is this significant?
Background:
What I tried:
