Stu
- Cheshire, UK
I have a client's Dell Dimension 5150 desktop that is not powering on. Nothing unusual prior to it happening, just came to switch on one morning and nothing. Just a blinking amber power switch.
First thought was the PSU, but this checks out OK in another machine, and installing a brand new 400 watt unit in the Dell makes no difference.
I've completely stripped the machine down to rule out any failed components. At the moment it's just the PSU, RAM, CPU, motherboard and front panel switch connected. No difference.
Now this is where the fun and games start. Just for tricks, I decided to try a third PSU I had lying around, a 500 watt job this time. Hooked the video card and monitor back up and tried my luck. It booted! Got POST output on screen and the CPU fan was turning nicely. Turned the machine off to try again, but then nothing. Back to square one and the orginal problem.
By now my curiousity is piqued, so for further laughs I decided to remove the CMOS battery. It then starts every time without it! BUT only with the 500 watt PSU. If I try the same with the original or the 400 watt job I get nothing but the blinking amber power light.
I'm really scratching my head with this one. Initial thoughts are maybe it's not getting enough juice, hence why it will only sometimes run off the 500 watt PSU (everytime with CMOS battery removed), but this can't be right since the original Dell PSU is 305 watts and nothing has been added. Also wondered if it might be the CPU fan, but this runs fine when I do get the machine going.
Any thoughts before I lose my sanity? Motherboard perhaps?
