Appletax
- U.P. of Michigan
Looking to replace my current build
CPU: Intel Core i7-7700K Overclocked (Aim is 5GHz), Delidded
CPU Delid Items
Graphics: EVGA 1080 Ti FTW3
Motherboard: ASUS Maximus IX Extreme
RAM: G.Skill TridentZ RGB 32GB DDR4-3200
Storage
Case: Thermaltake Core P5
Power Supply: SeaSonic 750W Titanium
PSU Sleeved Cables
OS: Windows 10 Pro x64
Liquid Cooling
I'll probably buy an excessive amount of tubing and fittings just in case and return whatever I don't use.
I don't know exactly which types of fittings I'll want to use.
I want it to look similar to this setup albeit with the GPU in the standard horizontal position.
- Wish I had it in me to wait for a 6-core Coffee Lake or Cannon Lake >
CPU Delid Items
- der8auer Delid-Die-Mate 2 to delid & relid (wish it were available state-side because it'd be cheaper)
- Thermal Grizzly Conductonaut Liquid Metal Thermal Paste (instead of Coollaboratory Liquid Ultra)
- [Liquid Metal Showdown] show that the Grizzly TIM is supreme
- High temperature silicone sealant with a long, thin nozzle (no idea which specific one to use). Would be nice if it were clear in color so it's not noticed?.
- Comes with a monoblock that cools the CPU, VRMs, and M.2 SSD (no need for a separate water block for the CPU)
- Probably won't notice any speed difference if I chose a higher clocked version, correct?
- Big fan of the RGBs to light up the case
- Wanted 2x16GB but they're not available - figure 4 sticks would be better looking anyways
Storage
- Samsung 960 Pro 512GB M.2 SSD (VROOM)
- Samsung 850 Evo 1TB SSD
- WD Black 5TB HDD
- It only officially supports an ATX mobo max, but I have seen others who've fit an E-ATX board - it just covers half the cable management gromets
- I love the idea of showing off all my components rather than having them inside a case and not nearly as visible
- The SSD would be mounted on the front and the HDD on the back
- Would be nice if the top were all black instead of having the silver piece
PSU Sleeved Cables
- What do you recommend? Looking for high-quality, flexible cables. Probably black & red in color.
Liquid Cooling
- Pump/Res: EK-XRES 140 Revo D5 PWM (Sleeved Cables)
- Radiator: EK-CoolStream XE 480 (Quad)
- GPU Waterblock: Guess I have to wait for one for the EVGA 1080 Ti FTW3 (can't use the EK-FC Titan X Pascal????)
- Also need thermal pads?
- Fans: Corsair ML120 Pro LED 120mm PWM x4
- Tubing: EK-PETG
- Fittings: Compression HDC x8
- Coolant: EK-Ekoolant Evo Blood RED (Premix 1L)
- CPU TIM: EK-TIM Indigo XS - Intel 115x
- Not sure about this
- EK-ATX Bridging Plug (24 pin)
