Appletax
- U.P. of Michigan
I'm looking to build a new system in the near future and am interested in liquid cooling but am very intimidated by it.
Here's the system I want to build:
What do you think of this config?
I wonder if it'd make any difference if I were to upgrade to their EK-CoolStream SE 360 (Slim Triple) radiator, which would be positioned in the front, and upgrade to a larger pump/reservoir, such as the EK-XRES 140 DDC 3.2 PWM Elite (incl. pump).
I've read that you should place silicone on the ends of the tubes to prevent leaks. See here:
https://pcpartpicker.com/forums/topic/131803-tips-for-water-cooling-enthusiasts-to-prevent-leaks
- Intel Core i7-7700K Overclocked
- EVGA 1080 Ti FTW3
- Asus Max IX Formula (Liquid Cooled VRMs with CrossChill)
- Samsung 960 Pro PCI-e SSD 512GB
- G.Skill TridentZ RGB 32GB DDR4-3200
- PSU: EVGA SuperNova 750 T2 Titanium or SeaSonic 750 Prime
- Sleeved PSU Cables (Red)
- WD Black 5TB HDD
- Corsair Crystal Series 570X RGB Case
- Windows 10 Pro
- EK-CoolStream SE240 (Slim Dual) - Mounted on the top
- EK-XRES 100 SPC-60MX PWM (inc. pump)
- EK-Supremacy EVO-Nickel CPU Block
- EK-DuraClear 3M Flexible Tubing
- I have a heat gun, so I could do hard tubing, but it seems like it'd be very challenging to figure out where exactly how to bend them so they're the perfect length & shape
- EK-ACF Fitting 10/33mm - Black x8 (Compression Type)
- They're all straight - none of them are at an angle
- EK-Ekoolant EVO Blood Red (Concentrate 100ML)
- EK-ATX Bridging Plug (24 Pin)
- EK-Cable Pump Testing Adapter
- EK-Cable Y-Splitter 2-Fan PWM (10CM)
- Bigger radiator + bigger, faster pump/reservor
