HCHTech
- Pittsburgh, PA - USA
I am quoting a wifi setup for a large home remodel and was looking at the possibility of using a complete Unifi stack. We use Hostifi's hosted controller, so the only two possibilities for Unifi routers are the USG and the Next Generation Gateway Pro. They will have gigabit internet service, so the USG is out. The dream machines can't use a hosted controller so they are out. This is a 4-story 100 year old house with stone and brick interior walls and 3 chimneys for the various fireplaces - so lots of APs. Probably 12-16 inside and 4 outside based on our walkthrough. They are doing tons of ethernet wiring, home theatre, smart lights, home automation stuff, security cameras, the works.
I'm looking at the specs for the NG Gateway Pro, and it strikes me as under-ported. 2 WAN ports and 2 LAN ports. Which makes me think I might be misunderstanding it's use-case. What exactly is the intended setup of this unit if it's only got 2 LAN ports? Are they essentially requiring L3 switches and VLANs for everything, then? It's $500, so definitely not an impulse buy, but it would be a small part of budget for a job this size - I'm just not sure it's the right thing.
What do you think?
What do you think?
