Vista error 80070020 on update
Essex. UK
I'm trying to install SP2 on vista home premium (SP1) and it is failing with the error: 80070020
Installation attempts have been through windows update & the stand alone installer.
I have followed the advise given here: http://support.microsoft.com/kb/883825. None of the advise given works in this instance.
Norton 360 has been fully removed via Norton removal tool (not add/remove)
Bit Defender has not been installed on the system.
I have done several malicious software scans with the computer coming back as clean.
I have ran a Windows update "Fix" tool & also manually disabled windows update in services & deleted the "software distribution" folder, rebooted and still the same error.
I have disabled & also reset windows built in firewall.
sfc /scannow finds no errors.
In addition 2 problem reports have been generated:
Product
Windows Modules Installer
Problem
CbsPackageServicingFailure
Date
02/09/2010 18:15
Status
Report Sent
Problem signature
Problem Event Name: CbsPackageServicingFailure
Stack Version: 6.0.6002.18005
Package: VistaSP2-KB948465~31bf3856ad364e35~x86~~6.0.0.18005
Status: 80070020
Failure Source: Resolve
Start State: Resolved
Target State: Installed
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 2057
Extra information about the problem
Bucket ID: 573000152
Product
Host Process for Windows Services
Problem
Windows Update installation problem
Date
02/09/2010 18:36
Status
Report Sent
Description
A Windows update did not install properly. Sending the following information to Microsoft can help improve the software.
Problem signature
Problem Event Name: WindowsUpdateFailure
ClientVersion: 7.4.7600.226
Win32HResult: 8024a005
UpdateId: 00000000-0000-0000-0000-000000000000
Scenario: Scan
SourceId: 101
Environment: Unmanaged
Locale ID: 2057
Bucket ID: 693722815
I would attempt an upgrade repair, however I do not have a Vista SP1 dvd.
Please note: A full backup of the hard drive has been made prior to all adjustments stated above.
Any help would be truly appreciated.
Try a DFT
Usually when all other potential causes of the problem have been eliminated, there's always the possibility that the cause is a dying hard drive, at InHouse where I work we've disinfected hundreds of machines, and part of the last steps is to ensure the system has Windows Update. When Windows Update breaks, we suspect a failing hard drive or at least one with bad sectors.
Try a Drive Fitness Test on the hard drive to see if it passes or not. I run CrystalDiskInfo to check the SMART status to see if there are any bad sectors, if there are, try a chkdsk /r which may take a few hours.
If neither of those fix it then the in-place upgrade may be the best option.
Have you tried stopping the crypto service and flushing the system catalog database approach?
1) Stop the Cryptographic service in services.msc or using the command prompt (net stop cryptsvc)
2) Rename (or delete if you live on the edge) the c:\windows\system32\catroot2 folder
3) Reboot
3) Reboot
I've also had some success with turning off UAC for the duration of the updates.
Rick
