occsean
- Oregon City, OR
Hi all...new here....Did a search and found one post but resolution not appropriate in this case.
Customer comes in with standard rogue AV infection. The usual fake security popups and asking to buy software..That was pretty easy to take care of. Nuke some registery entries, run rkill, MBAM, etc etc...So I get the malware off fairly easily. Usually at this point based on my experience Internet connectivity comes back. Not so today.
Adapter has a 169 address. Known good router, cable, etc.
have tried every command line reset I can think of i.e. mostly netsh int commands to rebuild the TCP/IP stack and fix Winsock. No joy. Static IP..packets will jump up to a few hundred than stop but still cannot get out past the adapter. /renew and /release commands return errors even in an elevated command prompt. basically nothing is acting as expected
Pretty convinced it is not the adapter (but open to being wrong). I suppose I could boot to a PE or Linux Live disk to determine that or pop another drive in there and blow another copy of Windows onto the box.
What I am REALLY trying to avoid here is nuking the install. I found some forum posts on other sites that detail a Vista repair hack that can be done by doing an inplace upgrade from within the OS itself. I kinda skipped the whole Vista thing to be honest and don't have a ton of experience with the OS. It amazed me there is not a repair install feature like XP's.
Just wondering if anyone had any ideas on stuff I can try here.
Appreciate any and all comments..
Thanks
Thanks
