Kirk007,
I posted a gigantic list of all KNOWN anti-virus/trojan/rootkit programs as the very first post in the antivirus forum. Do you see it? It lists every single one and what they are good for.
axel.dav is part of vbs_redlof.A , according to MartinM it litters a pc with axel.dav files which are 24 bytes in size, it attacks files with a selection of extensions - so the pattern of dispersion depends on what you have stored in different locations.
TrendMicro knows this puppy and can get rid of it. It is a visual basic script virus. You might use noscript.exe from norton (yes norton) it's just a free tool that turns off all scripting on your pc so you can stop the spread while you are trying to remove it.
This bug travels via email, infected files, and software exploits, and it is encrypted. It infects vbs, html, htm, asp, php, jsp, and htt files.
That means it can infect webservers. To spread copies of itself, it infects the stationery file, blank.htm of microsoft outlook express. This way every email you send is an infected email. It also uses vm activeX component to move across networks.
Microsoft made a patch for this in october of 2000. vm activeX is a part of microsoft virtual machine.
This bug hooks the Onload event and runs the KJ_start() function in IE when you open an infected webpage. It decrypts itself on your pc, it then initializes it's variables to get ready for the attack. If it finds wscript.exe in the windows folder it creates a copy of itself in there called kernel.dll. If it does not find it there, then it writes a copy of kernel.dll to windows/system which on reboot completely disables the pc.
You really really need to update your pc, these patches have been around since 2000. Good luck and let me know if I can help you further.
