Yes, I believe so. I offered to transfer her data to a loaner (which she said was not necessary) and didn't even mention a cost to do that.
@oldtech: As I mentioned, I love a challenge. If the MB is not toast, it just means cleaning up the mess, re-attaching the hinges to the top cover, and replacing the video cable. Unfortunately, the MB is not giving me video on the HDMI port so it may all be for naught, except I'm charging her for my labour to clean up the bottom cover and palm rest. If my colleague can get the MB to talk to us, everyone wins.
Re-attaching the hinges? Yeah right... The hinges are surely bent or broken, and the chassis being plastic probably needs a complete new clam-shell to do the job right and make it cosmetic. Anything less and she will NOT be satisfied because for $700 she is in-visioning a brand-new, refurbished laptop... The chassis, hinges, bezel, display cable, antenna /w coax cables, keyboard, and probably motherboard all have to be replaced!
Basically that is the entire lower half is more or less toast! Sure, there might be a good heatsink/fan, processor (if even removable), RAM sticks, bluetooth (if removable), wireless adapter, speakers, usb/headphones header, and perhaps even the rubber feet ;-)
My opinion would be to buy another, identical (refurbished) laptop with the same or better processor for the $775... move the hard drive over (or realistically image the data over to it if the original drive is going bad), make the MOST RAM between the two... Check the little things like which one has the best Bluetooth & wireless adapter...
I once fixed a laptop like this that had a A) Broken power button board, B) Plastic chassis for LED, C) Bezzel, D) Palmrest, E) Keyboard F) had to transfer the wireless antennas over, G) needed a battery, H) had a lost power adapter, I) needed a clean install of Windows/drivers/AV/Updates J) I rescued all the files first (of course)
She had a second laptop that needed an A) LED replacement.
I fixed BOTH of them for her for $95ish (my cost for all the parts sourced) because she truly IS probably my best friend, and I wanted to protect her from paying the big bucks.
The damage was caused by *drumroll* putting them in the bottom of a box when she moved. Had pots and pans etc on top of them!
After they were fixed, the repair lasted maybe a couple months before she broke them again.
