chrisappleby
- Nottingham, UK
This one was brought in by a customer over 2 months ago.
It is a Touchsmart 300-1015uk with an integrated AMD GPU (i.e. no PCI GPU installed).
It will not boot to BIOS, nothing on screen, the fans come on loudly after a few seconds and stay on. No faint inverter image on screen. PSU light stays on. Only other sign of life is a blinking light on the small USB board above the mobo.
So far I've tried reseating CPU and RAM, different RAM, different CPU (which works in other systems), BIOS reset by removing CMOS battery, hard power reset, disconnecting various/all mobo cables. Capacitors look ok.
From reading various repair reports, these systems seem rather trouble prone and parts are hard to source. Parts reliability is therefore a possible issue.
I've so far tried 2 replacement mobos, a replacement PSU and 2 replacement CPUs. In whatever combination I try them I get the same symptoms. The CPUs work ok in other systems. The PSU is a proprietry design but the voltages test ok.
The customer is understandably getting impatient and unless I can resell the parts I've tried so far my profit ill be near zero.
It's turning into the repair job from hell!
Any ideas anyone?
Any ideas anyone?
