Vicenarian
Ok, decided to upgrade the (outdated) nvidia 6200 TC PCI-E video card I had in my main HP PC the other day (THIS PC HAS NO ON-BOARD VIDEO).
Pentium D 920
4 GB DDR2
500 GB HDD
ASUS MB
etc.
Prepped the PC by removing all old nvidia drivers first of course.
Anyway, after doing some research, I decided upon a Sapphire ATI Radeon HD 5670 with 512 MB GDDR5. The box states this card only requires a 400 W PSU and it does NOT require a PCI-E power connector since it is considered a relatively low-power consumption card. (and I upgraded my PSU to a 400W SPI prior to the video card upgrade. I had all my hardware running on the stock 300W PSU fine before). Anyway, installed the 5670 and the computer wouldn't POST/display anything! Nada. I unplugged power to everything unnecessary in my PC and tried again, but nada. Nothing. No display. No POST. No beeps, nothing. All fans in the PC would spin up to full speed and just stay like that. Normally, all the PC's fans will spin at full for a couple of seconds, and then normalize, but with this they would just stay at full.
I put my old card back in, and the computer booted perfectly fine. At this time, I checked the settings in my BIOS, and made sure the video settings were correct. Next, I tried an old PCI (not PCI-E) ATI video card I had lying around, and the computer booted just fine with that.
So, I took the 5670 card back and got it exchanged for an EVGA Nvidia 9800 GT which was around the same price. Stuck it in, booted up just fine! This card says it only requires a 350W PSU, but it requires using a 6 Pin PCI-E power connector (which my PSU has).
Now what I'm wondering is this...is it possible that video cards can just be incompatible with some motherboards/hardware configs.? And, does it make any difference using cards with the same chipset (5670 for instance) but from different companies? Like, is a 5670 from Sapphire any different than a 5670 from say, MSI or something? Or, are some motherboards just picky between ATI/Nvidia cards? I thought this wasn't the case, but now I'm not sure. Or, is it possible that my PC just couldn't supply the necessary power solely through the PCI-E bus? I mean, theoretically the 5670 should have worked, from the specs anyway.
Edit: And yes, I am very much enjoying the 9800 GT
Pentium D 920
4 GB DDR2
500 GB HDD
ASUS MB
etc.
