nero problem
pnave01
I have been trying to back-up one of my external HDD to DVD using nero. It has failed already 5 times in a row, at first i thought it was nero so i used infra recorder then CDburnerxp all failed. I am using HP DVD-R ( which worked fine on 15 straight DVD's yesterday, before that i tried TDK), this has been happening of and on for the last 3 days but only today has it been constant.
Here is the nero log report.
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.8.5.0
Internal Version: 7, 8, 5, 0
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-110D>Version: 1.41 - HA 1 TA 0 - 7.8.5.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PIONEER DVD-RW DVR-110D>Version: 1.41 - HA 1 TA 0 - 7.8.5.0
=== Scsi-Device-Map ===
OtherPeripheral : SI Pseudo Device 0000 Si3114r5 Port 0 ID 16 DMA: Off
CdRomPeripheral : PIONEER DVD-RW DVR-110D nvatabus Port 1 ID 0 DMA: Off
DiskPeripheral : ST3500320AS nvatabus Port 2 ID 2 DMA: Off
DiskPeripheral : ST3500320AS nvatabus Port 3 ID 0 DMA: Off
DiskPeripheral : ST3320620AS nvatabus Port 3 ID 2 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-110D D: CDRom0
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 2047MB (2097151kB)
Memory in use : 16 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.1.2010
ISO compilation
3:01:51 PM #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
3:01:52 PM #2 Text 0 File Isodoc.cpp, Line 6608
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
3:01:52 PM #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
3:01:52 PM #4 Text 0 File Burncd.cpp, Line 3499
Turn on Disc-At-Once, using DVD media
3:01:52 PM #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2139663 (475:28.63, 4179MB)
3:01:52 PM #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
3:01:52 PM #7 Text 0 File DlgWaitCD.cpp, Line 2949
Recorder: PIONEER DVD-RW DVR-110D, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AM3
Disc Application Code: 64, Disc Physical Code: 193
3:01:52 PM #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
3:01:52 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2139664 (2139664) = #2139664/475:28.64
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2139664 blocks [D: PIONEER DVD-RW DVR-110D]
3:01:52 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: PIONEER DVD-RW DVR-110D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4382031872, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2139664 | 0 | 0x00
2139664 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
3:01:52 PM #11 Text 0 File SCSIPTICommands.cpp, Line 209
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
3:01:52 PM #12 Text 0 File Burncd.cpp, Line 4278
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
3:01:52 PM #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
3:01:52 PM #14 Text 0 File Burncd.cpp, Line 4397
Cache writing successful.
3:01:52 PM #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
3:01:52 PM #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 16x (22,160 KB/s)
3:01:55 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:01:55 PM #18 Text 0 File DVDR.cpp, Line 3192
Recording mode: Sequential Recording Mode
3:01:55 PM #19 Text 0 File DVDR.cpp, Line 3348
Start write address at LBA 0
DVD high compatibility mode: Yes
3:01:55 PM #20 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x062b7780: Len x648
3:01:55 PM #21 Text 0 File Cdrdrv.cpp, Line 9859
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
3:01:55 PM #22 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
3:01:56 PM #23 Text 0 File Cdrdrv.cpp, Line 1338
15:01:56.296 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #24 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.343 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #25 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.703 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #26 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.718 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #27 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.734 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #28 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.750 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #29 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.765 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #30 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.781 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #31 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.796 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #32 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.812 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #33 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.828 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #34 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.843 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #35 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.859 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #36 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.875 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #37 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.890 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #38 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.906 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #39 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.921 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #40 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.937 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #41 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.953 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #42 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.968 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:37 PM #43 Text 0 File Cdrdrv.cpp, Line 1338
15:02:37.984 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #44 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.000 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #45 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.015 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #46 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.031 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #47 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.046 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #48 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.062 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #49 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.078 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #50 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.093 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #51 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.109 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #52 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.125 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #53 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.140 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #54 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.156 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #55 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.171 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #56 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.187 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #57 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.203 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #58 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.218 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #59 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.234 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #60 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.250 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #61 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.265 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #62 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.281 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #63 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.296 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #64 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.312 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #65 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.328 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #66 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.343 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #67 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.359 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #68 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.375 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #69 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.390 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #70 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.406 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #71 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.421 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #72 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.437 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #73 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.453 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #74 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.468 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #75 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.484 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #76 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.500 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #77 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.515 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #78 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.531 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #79 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.546 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #80 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.562 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #81 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.578 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #82 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.593 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #83 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.609 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #84 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.625 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #85 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.640 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #86 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.656 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #87 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.671 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #88 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.687 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #89 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.703 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #90 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.718 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #91 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.734 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #92 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.750 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #93 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.765 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #94 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.781 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #95 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.796 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #96 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.812 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #97 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.828 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #98 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.843 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #99 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.859 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #100 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.875 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #101 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.890 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #102 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.906 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #103 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.921 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #104 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.937 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #105 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.953 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #106 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.968 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:38 PM #107 Text 0 File Cdrdrv.cpp, Line 1338
15:02:38.984 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #108 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.000 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #109 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.015 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #110 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.031 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #111 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.046 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #112 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.062 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #113 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.078 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #114 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.093 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #115 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.109 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #116 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.125 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #117 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.140 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #118 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.156 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #119 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.171 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #120 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.187 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #121 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.203 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:02:39 PM #122 Text 0 File Cdrdrv.cpp, Line 1338
15:02:39.218 - D: PIONEER DVD-RW DVR-110D : Queue again later
3:07:23 PM #123 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 1F 03 40 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 1F 00 40 0E 00 00 00 00 0C
Buffer x0c34df40: Len x10000
0x46 29 23 92 32 74 BF FC 2D F8 11 BC 54 80 14 7E
0xC2 98 44 AC 33 DB 4C 00 E5 E6 39 F5 C1 1D F8 04
0x28 C2 1F 6A D6 0F 84 A9 79 6A BB 20 E1 D3 33 6F
3:07:23 PM #124 CDR -1135 File Writer.cpp, Line 303
Write error
3:07:23 PM #125 Text 0 File DVDR.cpp, Line 3750
EndDAO: Last written address was 2032447 (1F033Fh)
3:07:24 PM #126 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 16x (22,160 KB/s)
3:07:30 PM #127 Text 0 File SCSIPTICommands.cpp, Line 254
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
3:07:34 PM #128 Text 0 File Cdrdrv.cpp, Line 11214
DriveLocker: UnLockVolume completed
3:07:34 PM #129 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Hopefully someone can help me, thanks a bunch for i have no idea how to read this logs.
Given you've tried different media and different programs, it may be the drive itself. You could try flashing the firmware: http://drivers.softpedia.com/get/FIRMWARE/Pioneer/Pioneer-DVR-110D-DVR-110DBK-DVR-110DSV-141.shtml This is the latest one for that model of drive.
I would also try lowering the burning speed too. I have some sony discs that my burner will only do at 8x despite being 16x discs. Everything else burns at 16x!
This is the link to the offical supported media for your drive.
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/pdf/DVR110D_MediaList_141.pdf
You won't see HP on the list as they just buy discs from a manufacturer and just rebrand them. The dye in the discs you used is "CMC MAG. AM3" (you'll see it in the logs) and is supported up to 16x.
If none of this works i would try the upper and lower filters fix:
http://support.microsoft.com/kb/314060
Bleh. Nero blows goats. Just backup data using dvdspan. nero is a bloated festering hog.
I dont like nero as a backup tool, personally i use norton ghost(no im not a fan of any of their other software, but this works well) it does everything you could ask from a backup prog
Thanks for all the help everyone, turns out my dvd drive doesn't seem to like the firmware update at all (which was already up to date). It will burn at 8X just fine but 12X or 16X its hit or miss usually miss, i don't mind to much takes a few minutes more but i'm patient.
Maybe i'll look into getting a newer dvd burner.
Thanks for all the help, especially DarDar.
Also thanks to everyone who gave me some alternatives to backing up with nero, will be looking into them.
I quit using anything faster than about 8x burning about a year ago. Too many problems with both expensive and cheap disks ended up as coasters.
