Need Help! - Sony Vaio Laptop
lciavarella
Kent, OH
I have a Sony Vaio Laptop Model: VGN-CS320J
· Tried to get an image to my NAS, one hour later cannot find destination drive
· Grab a hard drive hook to laptop shoot image to external hard drive, three hours later can’t find destination drive.
· Tried same things to PATA drive same results.
Plan B
Remove hard drive and install new SSD (120GB Kingston) and put fresh install Windows 7 Pro everything is peachy.
· Windows update spins for hours looking for updates nothing happens.
· Windows fixit and fix updates.
· Download WSUS install from updater stops installing twenty minutes into update.
· Use WSUS ISO that I made – same thing stops installing ten minutes into updates.
Plan C
· Install new memory - no joy
Got to walk away from this thing for now any suggestions will be appreciated.
Thanks
lciavarella
Maybe I read this wrong but did you remove the HD from the machine, put it on another machine and then try to copy/clone/image it that way ?
never removed hard drive was just trying to get an image to shoot onto an SSD. when that didn't work I had to do a clean install.
Must be in the air. I had an all-in-one Dell a few days ago that would only work if speed step was disabled in the BIOS. Never seen anything like it. Your problem here sounds like a motherboard issue if you've installed a new hard drive AND new RAM AND a clean install. With a laptop, there is really only one other option it could be. I'm assuming your doing all these things over LAN so the WiFi card wouldn't be an issue.
I think you hit it on the head Matthew. Let Windows update scan all night and it pushed out about 60 updates and there is about 178 with a new install. it must be short in motherboard because it works when it wants to , but most time it doesn't. What is really hard to believe is that the darn thing allowed a fresh install first try without any problems at all.​
Telling customer new laptop time.
