rudger
- Worcestershire, UK
I visited a new business customer today and they have a reasonable sized network and 2 HP Procurve V1700 (J9080A) 24 port Switches next to each other inside the cabling cabinet.
When I arrived these 2 switches were connected to each other via a 0.5m Cat 5 Cable between 2 100mbps ports on Each switch, I changed this over to use ports 24 on each of the switches as ports 23&24 are 100/1000mbps Capable now my main question is both switches have a fibre optic connectors would the customer see any improvement in network speed if they changed from a cat5 cable connecting the 2 switches together over to a fibre optic cable between the 2 switches, if so what type of cable do I require?
Thanks in advance
Rudger
Thanks in advance
Rudger
