Big Jim
- Derbyshire, UK
I have been tasked with "tidying up" this cabling.
The cabling was moved from its original location and all of the additional slack used up in doing so, and now I am left with this.
The shortest cable being about 6" long
The small shelf is temporary until I can go back and sort this out properly.
Normally we would obviously just stick it all in a small network cabinet, with a patch panel.
the issues I have
1 - as you can see some of the cables are too short, I assume in this scenario the only thing I can do is add a cat5 punchdown joiner for the very shortest cables.
2 - space is limited, to the left just in shot in this pic is a small door for access to a loft space
3 - power is about 8 feet to the right of this picture
4 - There is also an NVR to be added which will be around 12" deep, I don't think that a 450 deep cab is going to fit here.
My thoughts at this moment in time are to get a wall mounted patch panel and a small shelf above it (similar to the one in the picture but a bit deeper) with NVR on top, then the switch and the AP can sit on top of the NVR.
This seems like it is going to be messy looking though.
As you can probably tell I am an overthinker and most of you would probably just say (with regards to the mess), not my problem given that I have only been brought into this project at this stage, despite the electrician onsite repeatedly telling them to get me in to advise on networking.
the issues I have
