Tech bud
- Oshkosh, WI
Dell XPS P54G
System: Laptop will not boot, nothing on screen. Get a power light on the power button. 3 amber light flashes one White light flashes. According to what I found this says cmos battery is dead.
I did the standard, tested the ac adapter and it tested fine. Tested the dc jack, it tested fine. Plugged in the dc jack and the leads are getting the power it is supposed to. Tested the power to the battery leads. They had 3.86 volts getting to it. So those tested fine.
I unplugged everything one by one to try and get power to the screen, with everything unplugged. Including the cmos battery. I still get no power to the screen. Comes on for a moment, cpu fan begins to spin then it just shuts down again.
Not overheating as it was off for some time, wouldn't have shut down so quick.
So motherboard, but how to know for sure? it does have another board that functions with the power button. Button how do you test the ribbon cable? I guess I can assume it does its job as it does try to turn the laptop back on.
Do you all feel its the motherboard also? Hate no power up issues as hard to really know which part is which. I always tell them at this point, its better to get a new laptop. Looking up the motherboard, its $350 for it and I could be wrong and its the cpu
