sapphirescales
Well, this is an unusual one for sure. I have an HP laptop (newer 5th gen i5) x360 15" that won't recognize any hard drive. I replaced the cable but it didn't solve the problem. I can hear/feel the hard drive spinning up, but when you turn the system on all you get is a message that the hard drive can't be found. Things I've tried:
1. Replace the HDD cable
2. Flash the BIOS
3. Tried an SSD/other brand of hard drive
4. Tried booting in legacy and UEFI modes - doesn't make a difference
5. Resetting all BIOS settings to default (tried this before and after flashing the BIOS)
6. Cleaned the contacts between the motherboard and the HDD cable.
The computer boots fine from flash drives in both legacy and UEFI modes. Unfortunately, HP doesn't support anything other than a SATA based hard drive/SSD on this model so I can't even put in a mSATA or m.2 drive. There are no bent pins on the motherboard where the HDD cable connects and it's making good contact. I'm frankly at a loss here. Anyone else ever experience this? The next thing I'm going to try is a shim between the cable and the top part of the clip where it connects to the motherboard. Maybe it's NOT making good contact? I have no idea.
2. Flash the BIOS
