HouseOfTechs
How did you do the factory restore? I kept having the same problem too, as long as I was doing the factory recovery by using the F8 repair option. Once I performed the factory recovery using the manual method of extracting the "factory.wim" file, which is located in the recovery partition, using imagex, everything worked fine.
One thing you can try is installing an OEM copy if Windows 7. When doing this, delete the partition you are installing it to but leave the recovery partition intact. If this fixes your problem then it's probably the same issue I had and I can probably walk you through doing a factory restore using imagex and the "factory.wim" file on the recovery partition. If it doesn't, then you know for sure it's hardware.
yes i was doing it by using f8 and i will try to install with oem disk and leave partition in tact.. For the manual method is it better to put the factory.wim on a cd or can i apply it from the recovery partitions drive?
