ajc196
Ever run a Repair Installation (XP) only to be locked out because the activation Window won't come up once the repair is done (just sits at background with mouse cursor...)? Well I accidentally found a fix that has worked with a 100% success rate the past 7 times I've done it.
*Boot to safe mode without networking, log on to any account, and install or reinstall IE8. IE7 works too. Once you restart into normal mode, the activation window will come up like it should, and that will let you activate and get back in.
Hope this helps yall, let me know if you try it and it works for you.
