freedomit
We have a new V2832n router and have had major issues with it. The installation site is very simple, its a serviced office so an ethernet cable comes from a Cisco switch in the comms room and gives out an private IP via DHCP. When we installed the new 2832n to replace an old Netgear router it really struggled to get an IP address via DHCP and only worked around 10% of the time. If we set the connection to static then it connected but we were getting 50-90% packet loss when pinging google. The router also would often lock up and stop responding to ping on the LAN interface so would require a reboot. I had an old Vigor 2820n in my car so i installed that and it worked perfectly first time no problem, packet loss was 0% and internet speed good. Draytek support asked us to try various things but same issue, we were also able to replicate the problem in our own workshop so the unit was replaced under RMA.
Anyway, i went back today with the new 2832n and got the exact same problem. The router locked up twice and internet was all over the place. I changed the WAN interface from auto to 100 Full Duplex and it stopped crashing but internet wasnt right. Packet loss when pinging google was 10%, web pages took ages to load and i really struggled to get a speedtest to even run. I switched back to the 2820n and everything works fine again.
The WAN settings in both the 2832 and 2820 were identical, set to always on, static IP, MTU 1500 and auto negotiate.
Has anyone got an ideas what could be causing this issue?
