Yes, Dells stuck at their lowest speed is usually a non-Dell power supply but this has its OEM charger and I have tried another OEM Dell charger with no luck. When I plug in a non-Dell charger I get the splash screen about non-Dell chargers so I know it is sensing chargers correctly. When I brought it into the shop from the customer's place I saw the CPU peak at 3.08 GHz for just a few seconds before locking in at .38 GHz again. As a side note a few months back I put in a SSD but all was good at the time. I have Googled and read a ton of posts from other forums as this is not a rare occurrence but none of the suggestions have made a difference. I have -
Updated the BIOS
Turned off Speed Step
Booted on battery only. Booted on charger only. Rebooted on each.
Checked Intel drivers and ran Intel's assistant that found no updates available.
Pulled battery and unplugged and held power button down to drain the caps.
As I'm typing this the only thing I can think of is to check the CPU fan to be sure it works. Other than that I'm out of ideas. Suggestions before I admit defeat?
Updated the BIOS
