HFultzjr
- Central PA, USA
You cannot save the log file to the destination drive, unless you are making an image file and the destination drive has a formatted file system. You might be better off making a live linux USB thumb drive where you can save your log files there.
A full system seems to be overkill, unless you are running linux all the time. You could install it to a separate hard drive and simply switch boot drives when you need to boot from Linux. I have 4 or 5 drives with various linux flavours, just for that very purpose.
That being said, it is very rare that we use ddrescue around here.
Thanks for the reply.
I am making an image, so are you saying the USB drive needs to be a "Linux" format?
Good point on the Live USB....duhhh, why didn't I think of that.
I want to set up a full system, as I have several older machines that should run it well. Plus it fascinates me. I'm sure with a dedicated machine I would spend MUCH more time "playing" around with it. Good point on the various boot drives.
Big question????? Why do you rarely use ddrescue?
Never mind...I forgot who I was replying back to. I'm sure you have WAY more options than I have. You do Professional Recovery, correct?
Thanks for the ideas.
