Cleaned Up My Windows 11 Install After 2 Years. Here's What Actually Made a Difference
kartikpal
India
My laptop had been crawling for months. Boot times were painful. Apps stuttered constantly, and the fans spun up for no clear reason. Instead of wiping everything and starting fresh, I decided to dig in and actually fix it.
Startup Programs
Task Manager, Startup Apps tab. Half the listed programs had no business running at boot. Spotify, Discord, OneDrive sync, all disabled. Boot time dropped on the very next restart. Worth doing first.
Storage Sense
It's buried in Settings, under System, then Storage. Turn it on. Windows will clear temp files, old update caches, and the recycle bin automatically on a weekly schedule. That freed up around 14 GB without touching a single file manually. Yeah, it's frustrating how hidden this setting actually is.
Power Plan
Laptops default to Balanced mode, even when plugged in. Switching to High Performance under Power Options made everyday tasks noticeably snappier. Not just gaming. Regular browsing, file transfers, app launches all felt tighter.
Driver Updates
Windows Update doesn't always pull the latest GPU or chipset drivers. Going directly to the manufacturer's site and updating manually cleared up background CPU spikes I had been chasing for weeks.
Here's the thing: most performance problems trace back to neglected settings, not aging hardware. Check these four areas before considering a clean reinstall.
Nice @seashore. Just reading it had some obvious flags. At least to me.
1. Cleaned up W11 install after two years. A real technician wouldn't be doing that. The original install would have been what they wanted. And they would have used a generic install on a laptop, which has no bloatware like spotify, etc, instead of the OEM build.
2.
Stuttering. Means repeated starting and stopping. Often on the same word/phrase. Computers don't stutter.
3.
Power Plan. I've been futzing around with power setting since they had them. I have never seen a power setting that slows down computer performance or speeds up computer performance. They have increased battery run time. Which the 'bot failed to mention even though it's a laptop and run time needs to be maximized.
Over all it has that blah/generic aura about the piece. Just like back when we had a mini flood of chatGPT generated posts.
Unfortunately it's everywhere. youTube has had numerous videos uploaded of abandoned <insert whatever your want like giant yachts> being "rescued". Show people wielding pressure washers blasting serious surface rust and barnacles to reveal shiny painted or polished surface below. Pressure washers cannot remove rust or barnacles.
Obligatory reminder that it's impossible to empirically distinguish between AI generated and human generated content and anything that claims to do so programmatically is an objective liar.
Most likely a human using AI to write an article, in which case expect future articles containing affiliate links.
