spacecadetuk
- UK
I've got a clean install of windows 7 but it keeps running chkdsk at startup but finds no problems.I have tried to alter the registry with this command
autocheck autochk /k:C *
but it still keeps running at startup and if i try to stop it this way
From your Windows desktop, click on "Start" and select "Run". Bring up the computer's command prompt by typing "CMD" into the address bar.
Step 2
Type "fsutil dirty query d:" into the command prompt. This checks the computer's drive; most likely, it will encounter errors.
Step 3
Type in "CHKNTFS /X D:" in the command prompt. The "X" is the command that tells your computer not to check that drive the next time the PC reboots.
Step 4
Manually reboot the computer; chkdsk should not run, and you should be brought to your normal Windows desktop.
Step 5
Bring up another command prompt and type "Chkdsk /f /r d:" in order to run chkdsk on the offending, damaged drive. This will run the scan and uncover the contaminated files.
Step 6
Type "fsutil dirty query d:" into the command prompt; this will confirm that the damaged files have been repaired and that the drive no longer contains any errors.
it says its dirty but when i try step 5 it says
C:\Windows\system32>Chkdsk /f /r c:
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by ano
process. Would you like to schedule this volume to b
checked the next time the system restarts? (Y/N)
if i just run chkdsk (without the /f/r) it finds no errors but then when i do the fsutil dirty query it still says it's dirty
any help/ideas would be appreciated
Step 2
Step 3
Step 4
Step 5
Step 6
