MSgherzi
- Tehachapi, California
A customer brought me her Dell Dimension 8400 desktop PC claiming that a few weeks ago the CD and DVD drives were no longer being detected. I've been working on this thing for hours and I've tried Googling and using every possible solution I can think of. So, I need some help. Here's what I've done so far:
* Opened case and re-seated cables, power cords, and drives.
* Updated drivers
* Updated firmware
* Flashed BIOS
* Booted into Safe Mode
* Used System Restore and went back before the problem occurred
* Cleaned PC using CCleaner
* Looked in Device Manager and there are no drives or anything related to a CD or DVD drive, and nothing has a yellow question mark
* Ran DELL Diagnostics from partition Utility
* Deleted "UpperFilters" and "LowerFilters" files under:
HKEY_LOCAL_MACHINE/System/Curretcontrolset/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
* Used a utility to delete StarForce drivers. None were present.
Drive does NOT show up in BIOS or when I click My Computer, all that shows up is local disk C. BIOS shows "On board or USB CD Drive (not present)." My only suspicion is that it's a bad IDE connector because the drives eject perfectly fine. When I put a CD or DVD in, the green light lights up for a few seconds and then nothing happens, I don't even hear it spinning. So it's either a bad drive or bad IDE cables. But if the drives are bad, what are the chances that they both died at exactly the same time? I need some help here because I don't know much about hardware and many of you do.
Specs:
Microsoft Windows XP Home Edition
Version 2002
Service Pack 2
Dell Dimension 8400
Intel Pentium 4 CPU 3.20GHz 3.19GHz
1 GB of RAM
Thanks in advance,
Matthew
* Updated drivers
* Updated firmware
* Flashed BIOS
Specs:
Version 2002
Service Pack 2
Dell Dimension 8400
1 GB of RAM
Thanks in advance,
Matthew
