Vicenarian
Just a heads up, if you try to use the "Scan to Email" feature in the Brother ControlCenter 4 software, and get an error that says something like "no default E-mail application is registered on the computer (Error code CC4-121-xxxxxxxx), here's the solution (for Windows 7, anyway):
1) Go into the "Default Programs" control panel applet
2) Select "Set program access and computer defaults"
3) Select the downward pointing arrows to the right of the "Custom" radio button.
4) Under "Choose a default e-mail program", select the name of the email program you want. ("Use my current e-mail program" will probably be selected by default, but it won't work)
5) Voila!
It had me stumped for a while; under the regular Default Programs selection applet, I had the email program (WLM) set as the default for all extensions, but the Brother CC4 software wouldn't pick it up properly. But, after doing the above, it worked fine.
5) Voila!
