AtYourService
- CT
This is especially useful for installing Windows XP on a computer with an OEM license when you've only got a retail CD handy. You need a iso editor in order to open the iso ,change the .ini then save the new version of the .iso
heres directions on doing this with a free linux .iso editor
http://tinyapps.org/weblog/nix/200906190715_edit_iso_images.html
WinXP's setupp.ini controls how the CD acts. IE is it an OEM version or retail? First, find your setupp.ini file in the i386 directory on your WinXP CD. Open it up, it'll look something like this:
ExtraData=707A667567736F696F697911AE7E05
Pid=55034000
The Pid value is what we're interested in. What's there now looks like a standard default. There are special numbers that determine if it's a retail, oem, or volume license edition. First, we break down that number into two parts. The first five digits determines how the CD will behave, ie is it a retail cd that lets you clean install or upgrade, or an oem cd that only lets you perform a clean install? The last three digits determines what CD key it will accept. You are able to mix and match these values. For example you could make a WinXP cd that acted like a retail cd, yet accepted OEM keys.
Now, for the actual values. Remember the first and last values are interchangable, but usually you'd keep them as a pair:
Retail = 51882 335
Volume License = 51883 270
OEM = 82503 OEM
So if you wanted a retail CD that took retail keys, the last line of your setupp.ini file would read:
Pid=51882335
And if you wanted a retail CD that took OEM keys, you'd use:
Pid=51882OEM
Note that this does NOT get rid of WinXP's activation. Changing the Pid to a Volume License will not bypass activation. You must have a volume license (corporate) key to do so.
For screenshots of the Retail, OEM, and Volume License installs, click here.
Pid=55034000
Retail = 51882 335
OEM = 82503 OEM
Pid=51882335
Pid=51882OEM
