DocGreen
- South Bend, IN
Running into a weird issue on a W10 Pro machine. I've got it connected to my home network and registered through my Server2k12r2 domain server. When I browse attempt to browse the shares on my server (either by clicking on the server in Explorer, or entering the share path) it tells me that the path cannot be found (even though it clearly sees the server). It won't let me browse the shares until I've clicked "diagnose" on that popup window (which of course can't find an problem). Once I've tried diagnosing, it works just fine without any problems. It will continue to work fine until I go a short period of time without browsing the shares... in which case I have to rinse and repeat.
I'm also having trouble with saved RDP credentials to a Windows 7 machine on the same network. When I try to connect, I get an error saying "Your credentials did not work. Your system administrator does not allow the use of saved credentials to log on to the remote computer ____ because its identity is not fully verified." Entering the credentials manually allows me to connect just fine.
I don't have this problem on any other machine on my network. Googling the RDP error message returns a bunch of results telling me to change GP to allow the credentials to be saved, but I feel like that's not actually fixing the problem, which is that the W10 machine is unable to verify the identity of the remote computer... which I'm almost certain is related to the (if not the same) problem I'm having browsing server shares.
Anyone else run into this? I've looked for network services not running, but I haven't noticed anything out of the ordinary. Is there a particular service that may cause this if not running? I'm at a loss.
Thanks in advance!
Thanks in advance!
