HCHTech
- Pittsburgh, PA - USA
I am trying to remotely setup a new surface dock 2, and I'm thinking I got the wrong video cables, but before I purchase another guess, thought I would ask the hive mind since my googling isn't bearing fruit.
Client has:
Surface Pro 7
2 x Dell Ultrasharp 2415 monitors (connectors = HDMI, DP & mini-DP)
I purchased and shipped:
Surface Dock 2
2 x Startech USB-C to DP cables. Part number CDP2DP141MB. Here.
This isn't my first rodeo working with surface docks, but it IS my first with the new USB-C centered Dock 2.
The first thing I did was make sure that Windows was completely patched to date. So it is a 2004, with all current driver updates. After connecting the dock, I also searched for updates again, and when none was found, downloaded the Surface Dock Updater Tool. It reports the dock is at the latest firmware.
When both monitors are connected and everything is powered on, the Windows Display settings app shows all monitors and they are correctly identified by name. In fact, when I remote into the Surface, I can work with all monitors, move windows between them, set any one of them as the main display, etc. The trouble is that physically, the monitors are not displaying an image. They are giving the standard "no video input detected".
I had the client cycle through the video inputs for each monitor, but when they choose the DP input, no image is produced, even though the Surface itself thinks it is outputing video to that monitor.
I suspected that maybe there were different cables that had different capabilities, but I couldn't confirm that. I also looked at microsoft's documentation to see if there were any special requirements for the cables. I found none.
In looking at the documentation for the Startech cables I bought, I did find this:
"The Plugable USB-C to DisplayPort Adapter Cable enables a DisplayPort display to be connected to a computer via a USB-C port or Thunderbolt 3 port which supports “VESA DisplayPort Alternate Mode over USB-C" ("Alt Mode")."
I tried to ascertain whether the Dock 2 supported "alt mode" or not, but couldn't find a single mention about that anywhere.
I can't believe I need to buy monitors with USB-C connectors to make this work.
Does anyone have any hints for me?
Client has:
Surface Pro 7
Surface Dock 2
