JustInspired
- Kent, United Kingdom
These are what they look like.
The logo, company name, website, and date are auto-filled.
The client name COULD be autofilled, but it is more trouble than it is worth.
We make them in seconds and then hit print a few times (or dial up the number of prints).
They are 54 mm (2.1") x 25mm (1") in size and fit very nicely on a laptop lid or on the top of a tower.
I was somewhat concerned we'd get complaints, but not a single person has so much as expressed a gripe.
They are reasonably sticky, so they definitely adhere nicely, but if you wanted to remove it you most certainly can do so with little effort (and little residual stickiness).
I DID have a barcode generated (automatically based on client number) but it got busy + we aren't really scanning them back in for asset tracking, so I ditched it in favor of a cleaner look.
EDIT: we also have small colored dots (stickers of red, yellow, blue, green) from the dollar store that fit nicely in the white space. They indicate different issues. For instance, a HD labeled with a customer tag with a red dot means that drive is failed. Visually, it makes things VERY easy to ID and digest. Green is good to go (back to customer). etc. etc.
When I am looking at a shelf of systems I can simply track along the colors and the names and pretty much know exactly where each system is in the repair process.
We use colored dots a bit differently. We have a set of seven USB 2.5" hard drives that we use for imaging and FABS backups. Each drive has a different colored dot on it. The same color dot goes on the machine so we know exactly what drive contains the data for the FABS restore etc.
