xxsilk109xx
- Savannah, GA
I have a laptop here that is having some internet issues. I cant figure out what is going on, or possibly I have overlooked something.
Os:Vista
Had some virus's, a lot actually. Removed them with mbam, sas, then checked manually to see if anything was starting up or running. System seems clean from what I can tell.
Only issue so far is that once I got the wireless working I can get on the net, but when plugged in hardwire, it doesnt work. It also does not work in safe mode, and even in normal mode, whenever I look down at the clock i dont even see the icon with the screens and the X through it.
Checked drivers and they are as up to date as they can be.
Device is enabled and says its working properly.
I tried
Check and repair Winsock corruption.
Click Start. In the Start Search dialog box, type: cmd, and right-click cmd.
Click Run as administrator.
Type: netsh winsock reset, and then press the ENTER key.
Type: Exit and press ENTER.
Restart the computer.
Reset the TCP/IP protocol.
Type: netsh int ip reset, and then press ENTER.
After that I checked again to make sure drivers were up to date and they are.
Removed norton and mcaffee using their removal tools.
Checked internet explorer to make sure nothing is running through a proxy.
What have i missed?
Os:Vista
I tried
What have i missed?
