strange occurance today, took a call from a regular residential client for whom we have provided laptops and support for in the past.
He reported that he had an error relating to an Ip address conflict that he would like us to look into. the solution was simple, assign sttic IP's to his equipment.
without further ado i set about talking him through this on the first laptop by first getting the required info from an ipconfig run then putting the settings into the TCP/IP properties on the the adaptor. so far so good.
i then said we would need to repeat the steps on the other laptop(s) in the network to prevent further conflicts to which he replied there are no others. Huh?!
After a bit of head scratching and question asking it transpired that he had moved and now lives alone in a property with no broadband. The guy was piggy backing an neighbours wifi connection, and worse i had just assisted him in doing so
at first i was horrified, what was done was done and couldnt exactly play judge and tell him to undo the changes i had just made.
Then after a while i figured, in this day and age, if your are indeed dumb enough to broadcast an unsecured WAP then your kind of asking for it.
Naturally, of course i would'nt have assisted him in this had i have known the details.
what do you guys think, should i be loosing sleep over this??
