PcTek9
- Mobile, AL
Here's some tricks to speed up firefox...
about:memory "minimze memory usage"
about:config dom.max_script_run_time #of seconds script runs
about:config browser.tabs.remote.autostart false
about:config animate next set all TRUE to FALSE
about:config browser.cache.use_new_backend change value from 0 to 1
about:config network.http.pipelining true
about:config network.http.pipelining.aggressive true
about:config, set reader.parse-on-load.enabled to False
about:config, set reader.parse-on-load.force-enabled to False
about:config, set browser.pocket.enabled to False
about:config, set loop.enabled to False
browser.display.show_image_placeholders false
browser.cache.disk.capacity 5000
browser.download.animateNotifications to False
browser.newtabpage.activity-stream.feeds.telemetry to false
browser.newtabpage.activity-stream.telemetry to false
browser.ping-centre.telemetry to false
network.http.pipelining.maxrequests 8
network.http.pipelining.ssl true
network.http.proxy.pipelining true
network.dns.disableIPv6 true
network.prefetch-next to False (Only on slow internet connections)
security.dialog_enable_delay to 0
toolkit.telemetry.archive.enabled to false
toolkit.telemetry.bhrPing.enabled to false
toolkit.telemetry.enabled to false
toolkit.telemetry.firstShutdownPing.enabled to false
toolkit.telemetry.hybridContent.enabled to false
toolkit.telemetry.newProfilePing.enabled to false
toolkit.telemetry.reportingpolicy.firstRun to false
toolkit.telemetry.shutdownPingSender.enabled to false
toolkit.telemetry.unified to false
toolkit.telemetry.updatePing.enabled to false
Use ublock origin instead of adblock, better yet use pihole
uninstall slow extensions
use addon called 'disconnect'
disable access to all multimedia devices, e.g. camera, microphone, etc
settings: performance heading: uncheck use recommended performance settings box
then set to 1 process per core ex: on a 2 core system let 2 processes run.
settings: options: privacy & secruity tick box "Prevent Accessibility services..."
settings: options: privacy & security turn tracking protection on
settings: options: general heading untick "use recommended performance settings" then uncheck box "use hardware acceleration"
* I'll come back and edit this more later, to fix it up.
