SLI ready Power supply recommendation
coffee
United States
I got a "cyberpower" gaming rig in the other day and looks to be a bad power supply. No big deal. Except finding one to match the specs with good quality at an affordable price is a problem.
The PSU is a Ultra ULT-LS5000P 500watt. I think I want to go a bit larger say about 600 watts because the rig has some neon lights, Dual video cards. Also, The Motherboard uses a 8pin connector. The video cards both use 6pin connectors.
So, Any recommendations would be appreciated.
Thanks,
coffee
What a junk PSU in a dual card 'gaming PC'!
Just look up the mobo, cards etc. and get a decent PSU. Thing is because of all the junk PSUs around, the GPU manufacturers give crazy min specs for their cards: if a card draws 150W they end up recommending a 500W because the junk '500W' ones can really only supply 250W or so.
Just stick to a Seasonic made one (Seasonic, some high Corsairs, some XFX etc.). There's a PSU reivew database
http://www.realhardtechx.com/index_archivos/Page541.htm
which is handy is you're unsure.
What video cards are they? If they only take a single six-pin each, then 600W should be good. I really like the Seasonic X650 (I personally have two), it has an 8-pin CPU and four 6-pin PCIe connectors, gold-rated efficiency, fully modular, quiet, etc. It's not cheap but you get what you pay for.
EDIT: I always check with jonnyguru.com or hardocp.com on potential PSU purchases because they actually properly load-test them. Most sites just build the highest-end rig they can and if the PSU doesn't blow up give it editor's choice.
Ok, Thankyou everyone for your replies! Thanks for the good links too!
Because the repair has to be a quick one (I cannot wait a week to ship it in) I am going to try this one:
Viotek Pro ps-vtk-800w-24pin
Give it a shot and next time I will be more prepared with the good ps database!
thanks all!
coffee
thanks all!
coffee
That PSU should work, but only if you treat it as a 600W at most. Those eBay specials usually have overly optimistic wattages listed.
This would be a much better quality PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 $90 and there is a $20 rebate
