YeOldeStonecat
- Englewood Florida
I was told earlier in this thread to disable DHCP on the router once it was enabled and setup in Server 2012?
Yes..>I always say that....I see that mistake done way too many times...I see the mistake of DHCP running on the router, not the server. Proper way is..DHCP should be run on the server. DHCP from anything else other than the server will lead to active directory being broken down the road, causing problems, various things won't work correctly. Causing more headaches down the road. You need to resist the pizza tech approach of just caving in and letting DHCP run on the router.
Just a quick heads up...Windows DHCP service has a few steps to be done to get it going. Service should be on auto start...and in DNS management...it should be "authorized"...did you run through the DHCP setup wizard and complete it all properly? Check event logs, look at client leases. Plug in your own laptop and run ipconfig /all and ensure things look correct, look in DHCP management at leases.
Re: VPN on the router...Draytecs are not common over on my side of the pond...so I'm not familiar with them. But I will say that "most" biz level routers will have a VPN service that has either its own separate DHCP service just for the VPN clients...yet can have DHCP for the green zone (primary LAN) disabled. And a few others will allow you to setup "DHCP relay" to the Windows server...so the Windows Server will hand out leases for the VPN clients coming in from the routers VPN service.
