ComputerPro
- Saginaw Michigan
I've seen the short video clip of them using it for checkboxes for the work order which seem very cool. Just wondered how everyone uses their custom fields in RS. There are so many possibilities, it would be nice to have some ideas listed here. Example one called 'Laptop' which could have a drop down for OS, notes section for noted damage, yes/no box for 'has charger' etc.
The vid they showed had 'Phone Repair' for a field with a text box for 'IMEI' and a bunch of check boxes for 'water damage, broken volume buttons, broken digitizer, Prev repaired etc'
Also, for the 'Issue Type' we are starting to just put the device; Desktop, Laptop, iPhone, iPad, Tablet, Printer etc. Reason is it's tracked with the circle stats graph on the bottom of the home screen and its too granular to have an actual problem listed as there are so many. Also, the device type shows up this way in the tickets screen so you can find things very quickly by knowing what it is without the need to drill down into the ticket to see what kind of device it is.
Also anyone have any nice 'Canned Responses' that they use that work out well?
