[REQUEST] Need help creating swap file with Easy2boot
ell
Hi, I put easeus recovery on a easy2boot usb drive and made it bootable for uefi by converting it to a imgPTN in easy2boot. It works fine but halfway through the scanning process I get a error that theres not a big enough memory swap file. I went here http://www.easy2boot.com/add-payload-files/adding-uefi-images/ but can't understand this part:
How to use two partition images
E2B will recognise any valid E2B file that starts with the file extension .imgPTN (not case sensitive). If a second file exists in the same folder which has the same file name but no extension, then E2B will also change the MBR partition table so that the 3rd entry points to that file:
fred.imgPTNLBAa >> ptn #1 (must contain E2B MPI files)
fred. >> ptn #3
The partition image #3 can contain any filesystem (NTFS, ext3, etc. or even be unformatted). It could be used as a persistence or swap area.
You can also use the extra partition to install a full linux OS into (e.g. KALI).
Note: SWITCH_E2B.exe will also switch-in both partition images (if present).
Read more: http://www.easy2boot.com/add-payload-files/adding-uefi-images/
anybody know how to make the swap file image?
